1703 Discussions
a=b=c; or b=c; a=b; which has higher time efficiency?
fatalme
a=b=c;
or
b=c;
a=b;
Ilnar
both constructions are equal, first one is just shorter syntacs of the second one
Dost__Conrad_W
The compiler will optimize them to the same code.
jimdempseyatthecove
Quoting conradca
Excepting when b and a are volatile.
dwms
An interesting exercise would be writing the code to do both and then reviewing the assembly generated by the compiler.
Assuming this is not a complex data type, don't forget:
a=c;
b=c;
