data placement
karimfath
hello
can i mesure the cost when a thread access data in l2 or ram to a do write or read operation.to evaluate difference between the two operation when data is in l2 and data is in ram in centrino duo system
thanks
Dmitry_Vyukov
Valued Contributor I
Quoting - karimfath
You must make something like this:
- start 2 threads, bind them to different cores
- create following object:
struct X
char pad1 [128];
int data;
char pad2 [128];
X* g_x = new X;
- create semaphore for communication between threads
In order to measure cost when data is in L2$ and in foreign L1$:
1. First thread writes to g_x->data, and signals semaphore
2. Second thread wakes up and loads g_x->data
In order to measure cost when data is in RAM, you must flush data from cache with clflush instruction.
TimP
Quoting - karimfath
hello
thanks
Have you considered to what extent PTU will help with your investigation?
http://software.intel.com/en-us/articles/intel-performance-tuning-utility-31-update-3
Dmitry_Vyukov
Quoting - karimfath
struct X
char pad1 [128];
int data;
char pad2 [128];
X* g_x = new X;
DDd1
Quoting - Dmitriy V'jukov
struct X
char pad1 [128];
int data;
char pad2 [128];
X* g_x = new X;
Nice tip. Does anyone know of a small utility library that packs together small tips like this to do parallel performance measurements, and instrumentation in our own applications? Probably something they have laying around and can be of use to others ;)
