errors while compiling tbb
xinyuhou
I am totally new to tbb. Just followed the doc "getting started" and tried the parallel forexample which works fine. When I tried to add tbb into my own project there are several compiling errers which will be listed in the end. All I did is just add #include"tbb/parallel_for.h" and #include "tbb/blocked_range.h" into one of my cpp file that is the place whereI am gonna do parallel.
Thanks in advance
Jerry
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(44) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(44) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(53) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(53) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(59) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(59) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(65) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(65) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(71) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(71) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(92) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(93) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(94) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(110) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(92) : error C2059: syntax error : '{'
1> c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(135) : see reference to class template instantiation 'tbb::tbb_allocator' being compiled
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(92) : error C2334: unexpected token(s) preceding '{'; skipping apparent function body
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(93) : error C2059: syntax error : '{'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(93) : error C2334: unexpected token(s) preceding '{'; skipping apparent function body
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(94) : error C2059: syntax error : '{'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(94) : error C2334: unexpected token(s) preceding '{'; skipping apparent function body
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(110) : error C2059: syntax error : '{'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(110) : error C2334: unexpected token(s) preceding '{'; skipping apparent function body
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(182) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(183) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(185) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(182) : error C2059: syntax error : '{'
1> c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(192) : see reference to class template instantiation 'tbb::zero_allocator' being compiled
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(182) : error C2334: unexpected token(s) preceding '{'; skipping apparent function body
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(183) : error C2065: 'a' : undeclared identifier
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(183) : error C2056: illegal expression
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(183) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(183) : error C2473: '' : looks like a function definition, but there is no parameter list.
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(184) : error C2143: syntax error : missing ';' before 'template'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(153) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(153) : error C2059: syntax error : '='
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(153) : error C2238: unexpected token(s) preceding ';'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(158) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(158) : error C2059: syntax error : '='
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(158) : error C2238: unexpected token(s) preceding ';'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(168) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(168) : error C2059: syntax error : '='
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(168) : error C2238: unexpected token(s) preceding ';'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(171) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(171) : error C2059: syntax error : '='
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(171) : error C2238: unexpected token(s) preceding ';'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(153) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(158) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(168) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(171) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(204) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(215) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(218) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(224) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(227) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(229) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(230) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(204) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(215) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(218) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(224) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(227) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(229) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(230) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(267) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(274) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(284) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(286) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(288) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(290) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(293) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(302) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(268) : error C2065: 'src' : undeclared identifier
1> c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(323) : see reference to class template instantiation 'tbb::movable_exception' being compiled
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(269) : error C2056: illegal expression
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(269) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(269) : error C2061: syntax error : identifier 'src'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(270) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(270) : error C2059: syntax error : 'constant'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(271) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(271) : error C2061: syntax error : identifier 'src'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(272) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(272) : error C2143: syntax error : missing ';' before '{'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(272) : error C2334: unexpected token(s) preceding '{'; skipping apparent function body
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(323) : fatal error C1075: end of file found before the left brace '{' at 'c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(120)' was matched
SergeyKostrov
Valued Contributor II
This is a duplicate and the problem is SOLVED. Please take a look at a TBB thread at:
http://software.intel.com/en-us/forums/showthread.php?t=106823&o=a&s=lr
