1707 Discussions
multiple reduction on stl::vector gets wrong results
Sean_D_
In the following test code, I use omp declare reduction on stl::vector.  Using icpc 17.0, omp parallel reduction works correctly on a single stl::vector.  However, when I attempt to reduce to two separate vectors, v1 & v2, it returns v1=sum(v1)+sum(v2) and v2=0.0 (where sum is across threads).  By my reading of the standard, I would expect it to return v1=sum(v1) and v2=sum(v2).  This is what GCC 6.3 does.
Can my omp directives be tweaked to work with icpc 17.0?  Or is there another problem?
Thanks in advance,
Sean
// http://stackoverflow.com/questions/43168661/openmp-and-reduction-on-stdvector
#include <algorithm>
#include <functional>
#include <iostream>
#include <vector>
#include <omp.h>
#pragma omp declare reduction(+ : std::vector<double> : std::transform(omp_in.begin(),omp_in.end(),omp_out.begin(),omp_out.begin(),std::plus<double>())) initializer (omp_priv=omp_orig)
int check1(int size){
  std::vector<double> result(size,0.0);
  int npart=100;
  int n;
    int i;
// Works in GCC 6.3, Intel 17.0:
#pragma omp parallel for private(i,n) reduction(+:result)
    for (n=0; n<npart; n++){
      for (i=0; i<size; i++){
	result  += i;
  int fail=0;
  for (int i=0; i<size; i++) {
    if (result != i*100){
      fail=1;
    std::cout <<"i="<< i<<" "<<result<<std::endl;
  return fail;
int check2(int size){
  std::vector<double> result2(size,0.0);
  int npart=100;
  int n;
    int i;
// Works in GCC 6.3, fails in Intel 17.0:
//#pragma omp parallel for private(i,n) reduction(+:result),reduction(+:result2)
#pragma omp parallel for private(i,n) reduction(+:result,result2)
	result  += i;
	result2 += i;
  int fail=0;
    if (result != i*100 || result2 != i*100){
      fail=1;
    std::cout <<"i="<< i<<" "<<result<<" "<<result2<<std::endl;
  return fail;
int main(int argc, char *argv[]) {
  int size;
  if (argc < 2)
    size = 10;
  else
    size = atoi(argv[1]);
  int fail1=check1(size);
  int fail2=check2(size);
  return fail1+fail2;
TimP
I guess the question would get more rapid attention on the C++ forum or with a submission to supporttickets.com
I'll try this myself when I get a chance.
Sean_D_
Thank you I just resubmitted to the C++ forum.
