Can someone please advise if the Compute Element CM11EBv58W, or CM11EBi58W, supports installation of Windows with S3 sleep, or only with S0 Modern Standby?
TIA
Hello rgord1,
Thanks for waiting for a response.
You can check the system's supported sleep states by opening PowerShell and entering the command powercfg /availablesleepstates. It will return all the sleep states supported by the system. (See the article: How to check which power sleep states are supported by your PC on Windows 10 | Windows Central): https://www.windowscentral.com/how-determine-power-sleep-states-supported-windows-10
We performed a lab. With Windows 11 with Modern Standby enabled (by default), it's showing that S1, S2, and S3 are not supported. See the image attached:
If you disable modern standby via registry key (How to Disable Modern Standby in Windows? - Appuals.com), S3 is available. However, you must consider that making changes to the registry key is not supported by Intel, and the best would be to consult with Microsoft.
https://appuals.com/disable-modern-standby-windows/
Jean O.
Hello rgord1,
Jean O.
Hello rgord1,
Jean O.
Hello rgord1,
I am glad to know the information helped. Hopefully, it will help other community members. Since the thread is now solved, I will close it. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Jean O.
