Intel® NUC Elements
Support for Intel® NUC Compute Element, Board Element and Chassis Element
113 Discussions
Front Panel Header on CMB1ABA
rchaney
I'm using the CMB1AB.  The datasheet I have says that the front panel header is a 2x12, 1.25mm pitch connector.
Looking at the part on the board, it's a 12 pin connector (2x6) and has a 2mm pitch.
What part is this?  More importantly, how do I connect to it?  I intend to test it out with a 2mm pitch component.
Is there a more recent version of the datasheet?  The one I have is Revision 1.4.  I can't seem to find a more updated one.
Steven_Intel
Hello rchaney,
We appreciate the feedback provided. The revision 1.4 is the most updated version of the document, it has a 2x6 header with 12 pins, the document indicates what each of the 12 pins is for.
Please let me know if you have any concerns.
Steven G.
Steven_Intel
Hello rchaney,
We are going to research the information. As soon as I have an update, I will let you know.
Steven G.
Steven_Intel
Hello rchaney,
We can confirm the front panel header it is a 2x6 header (12 pins) as stated in the latest document https://www.intel.com/content/dam/support/us/en/documents/intel-nuc/nuc-elements/CMB1AB_PROD_SPEC.pdf
Do you have something different on your board? If so, could you please provide a picture of it?
Steven G.
rchaney
Hi, The datasheet you linked to is the one I'm looking at as well.  The datasheet describes the connector incorrectly.
Steven_Intel
Thank you for your response, rchaney.
I will work on this case with our team. As soon as I have an update, I will let you know.
Steven G.
Steven_Intel
Hello rchaney,
Steven G.
rchaney
The 1.4 datasheet is only half correct.
It says 1.25mm pitch, but the real connector is 2mm pitch.
It says 2x12, but the real connector is 2x6
The mistakes are highlighted and corrected in the attached picture.
Steven_Intel
Thank you for reaching out and providing us with valuable feedback.
Since the thread is now solved, we will close it. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
