Intel® NUC Elements
Support for Intel® NUC Compute Element, Board Element and Chassis Element
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
119 Discussions
Intel Management Engine reagiert nicht mehr - wie kann das Problem behoben werden?
OCarl2
Fehler während des Bootvorgangs: "(A7) ME FW Downgrade Request MeSpiLock failed" und "HECI disabled proceeding with boot"; Fehler während eines Update-Versuches ME: Error 86, 81, 8743 gemäss Beilage (Foto); Wie kann das Problem behoben werden?
LeonWaksman
What is your NUC model? This is NUC forum.
Leon
OCarl2
Hello, seems as if I am in a wrong forum. I am using an HP Probook 650 G2. HP could not help, so I tried to get help from Intel. Is there any forum available for such kind of tasks? Thanks, Oliver
AdrianM_Intel
Hello OCarl2,
Were you able to check Leon's post?
Adrian M.
OCarl2
Sorry for the delay, yes I could. Regards, Oliver
AdrianM_Intel
Hello OCarl2,
Thank you for your reply.
I will recommend you to contact HP since the system has its own customizations performed by HP also, the recommended driver for Intel management engine should be provided by the system manufacturer HP ProBook 650 G2 Notebook PC.
Adrian M.
OCarl2
Thank you, yes, this should be the correct path. Instead, HP is not capable to solve this issue. They offered a new motherboard price 450 swiss francs. The device age is 1.8 years, no warranty....
So we close this issue now.
Oliver
LeonWaksman
Hi Oliver,
I want just to say that in many cases such error disappears after updating Bios to the latest version. In addition check in laptop download site if there is a new Intel Management User Interface driver for download.
Leon
OCarl2
Hi there, thanks, this is a good advice. I have done that both immediately after the error occured the first time.No chance... In fact, the bios tells me the state of the IME to be version 0.0.0.0. Even the tool MEInfo cannot connect to the IME anymore - seems dead. Regards, Oliver
AlHill
Sounds like a botched bios update. You need to get your bios/ME straightened out with HP, as it is their bios.
Doc
