Intel® NUC Elements
Support for Intel® NUC Compute Element, Board Element and Chassis Element
113 Discussions
Linux Kernel is unable to load igb driver
Zeeawk
Hello out there, I have an issue with the igb driver on a 5.18.7 kernel. With e.g. 4.13.5 I am able to recognize and enable my Intel NUC.
by booting the 5.18 kernel I only can tell, that I get neither a eth-n interface nor an IP address. the only trace I have is from dmesg which says:
"igb: unknown symbol i2c_bit_add_bus (err -2)"
by searching the kernel source code, I found out that this symbol i2c_bit_add_bus is provided by the i2c_algobit module. This module is within the kernel, according to config file. Bit if I look into /proc/kallsyms it does not appear there. But its already activated within the .config file as CONFIG_I2C_ALGOBIT=y
With 4.13.5 however it's visible:
cat /proc/kallsyms| grep i2c_al
ffffffffa049bbf0 T i2c_bit_add_bus      [i2c_algo_bit]
So Im not sure what is the status there, does anyone know what the problem might be?
Thank you in advance
/chris
Jean_Intel
Hello Zeeawk,
Thank you for posting on the Intel️® communities. I am sorry to hear that you are experiencing issues with the drivers with your Intel Nuc.
  • What is the Intel Nuc model you are using?
  • What is the Linux* Distribution and version?
Jean O.
Jean_Intel
Hello Zeeawk,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello Zeeawk,
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
