Intel® NUC Elements
Support for Intel® NUC Compute Element, Board Element and Chassis Element
NUC7i7bnh
Hello4
Hello!
I have NUC7i7bnh and I hold on long time power button, after then my NUC not turning on. To a big plus, I know how to repair boards. Please help me with my comuter, I need to work on it. It would be great if you could give me the block diagram and boardview. Thanks!
LeonWaksman
The block diagram and board view you may find in the Technical Product Specification.  Could be that the Power Switch contacts are contaminated. You may try to spray over this switch with some Contact Cleaner. Wait few minutes and check if helped.
You may verify if the problem is caused by the Power Switch, by replacing it with momentary switch connected to pins 6-8 of the Front Panel Header (see 2.2.4.4 trough 2.2.4.4.4 in the Technical Product Specification).
Leon
Hello4
To be precise, the problem arose when replacing the power button itself. When the button was removed, the contacts of the plus and the pin holed to the textolite were shorted. Thus, a short circuit was obtained. That's why I want to check all the voltages according to the scheme and identify what is wrong. And in the provided scheme, unfortunately, there is not enough information to identify a malfunction of the power supply system, it would be great if you could help me solve that problem.
Hello4
In simple terms, the positive contact of the power button and textolite was closed ... As a result, we have an unusable board. Please help solve the problem!
LeonWaksman
Hi @Hello4
I don't have the board schematic and I'm doubt that you may obtain it here. But instead of using the regular Power Switch, did you tried the momentary short between pins 6-8 of the Front Panel Header? If you will remove this shorted Power Switch, will be the short circuit disrupted?
Leon
Hello4
Button has been removing and two pins were accidentally torn out. When trying to restore the torn pins, they reached the textolite and closed the positive pin of the button with the textolite, while the button itself was no longer on the board. Absolutely any component on the board could burn. Board not started when shorted 2 normally pin the button.
DeividA_Intel
Hi Hello4,
Due to this product being discontinued, Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help. You may also find the Discontinued Products website helpful to address your request. Thank you for understanding.
Discontinued Products:
https://www.intel.com/content/www/us/en/support/discontinued-products.html
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
