Intel® NUC Elements
Support for Intel® NUC Compute Element, Board Element and Chassis Element
83 Discussions
NUC9I7 not detect Quadro P2000
Timon
Hello, Everyone!
I tried to add Quadro P2000 to my NUC9i7. GPU doesn't recognize BIOS and Windows. I checked the slot by another board (network card) it worked. The GPU works in another system.
Also, I tried to remove SSD because PCIe lines split between devices but I had the same result.
BIOS updated.
Do you have any ideas on how to solve the issue?
Thank you for any advice!
David_G_Intel
Hello Timon
Thank you for posting on the Intel️® communities. Please share with us the following information:
  • Which BIOS version do you have?
  • Did you test another GPU on the system?
  • Did the GPU work on this system before?
  • Please share the Intel® System Support Utility (Intel® SSU) results to investigate:
David G
Timon
I solved the issue by replacing the graphic card. The issued card was marked as Dell, the new card is original NVIDIA (PNY). Both cards operated well on test MB. But only PNY runs in my NUC.
Thank you for your help!
Request closed!
David_G_Intel
David G.
David_G_Intel
David G.
