I installed a Samsung 970 evo in the Nuc9i7qnx pch m.2 slot, but it doesn't get the proper speed.
The original speed should be over 3000MB/S for Read, but it operates at half the speed of about 1900MB.
For what reason?
I have a NUC9V7QNX. Compared to yours:
https://ark.intel.com/content/www/us/en/ark/compare.html?productIds=190109,190103
I have a Samsung 970 EVO+ 512GB installed.
My crystal diskmark shows:
Al's system is identical to yours, barring its support for vPro. If your system continues to have this issue (you've tried rerunning after reboot?), I suggest you open the system back up and reseat (i.e., remove and then reinstall) the SSD. If this fails to fix the issue, I suggest you replace this SSD (you would not be the first person to come here complaining about what turns out to be a bad SSD).
Hope this helps,
