Intel® NUC Elements
Support for Intel® NUC Compute Element, Board Element and Chassis Element
88 Discussions
Nuc 11 Extreme NUC11BTMi9 Bios update
Decca
New Contributor II
Does not work. Latest BIOS update file DBTGL579.0062.EBU.EXE gives the following error when run:
49 - error a platform condition has prevented executing
This from an elevated command prompt in Windows 11.
n_scott_pearson
Super User Retired Employee
Download the CAP file and try using the F7 or Power Button Menu methods to install it. For more information on the processes, consult this page: Intel NUC BIOS Update and Recovery Instructions for Aptio V BIOS Core.
Hope this helps,
Decca
New Contributor II
F7 did not work. No reaction from the NUC.
Power button menu option did not work. The menu appeared, F7 was pressed, nothing happened.
The UEFI Shell Update option DID work!
It should not be that awkward to perform a BIOS update.
More work to do there, Intel....
DeividA_Intel
Hello Decca,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® NUC 11 Extreme Kit - NUC11BTMi9.
1. Does the issue with the BIOS update persist?
2. Can you take a picture of the error?
Deivid A.
Decca
New Contributor II
My post describes exactly what process I went through, each option in turn as follows:
1 - Express BIOS Update (Windows-based)
2 - F7 Update
3 - Power Button Menu Update
4 - UEFI Shell Update
There is nothing more to tell you. Only option 4 worked, as I said.
DeividA_Intel
Hello Decca,
I am sorry for the misunderstanding. In this case, I just wanted to confirm if you need help with the update or if you were able to perform it with the "UEFI Shell Update".
Just let me know if you need further assistance.
Deivid A.
DeividA_Intel
Hello Decca,
I reviewed your post, please let me know if the issue was resolved, if not, do not hesitate, just reply back.
Deivid A.
DeividA_Intel
Hello Decca,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
