Can you provide sourcing information for the SATA cable for the BKNUC9VXQNB Compute Element H-Series?
The combined data and power connector is described on page 42 of the Technical Product Specifications as FPC Style 16-pin connector.
Hello NikosZ
Thank you for posting in the Intel Community.
I would like to confirm that you are looking for the availability of the SATA cable of the Intel® NUC?
Do you currently have any chassis for the Intel® nuc? Did they come as a bundle?
Leonardo C.
No Intel chassis. Just a bare Compute Element board.
Hello NikosZ
Thank you for the details, allow me to look into your request for the SATA cable, I will be posting back as soon as possible
Leonardo C.
Hello NikosZ,
Apologies for the delay, it was a bit difficult to get the requested information.
The type of SATA connector on the board is "FPC,0.5mm,Gold 15u inch,Black,SMD-16P,ROHS,HF" unfortunately I can only recommend that you try to find a matching cable for this connector.
We do not provide this cable as a fulfillment item.
Ronny G
Can you at least post the pin out of the connector so we know that if we can find a cable, it's the correct one and we don't short out something on the very expensive computer element or the hard drive?. Or at the minimum refer us to a 3rd party that sells the cable. To tell someone to try and find the cable elsewhere isn't a very good answer if you are looking for repeat business. For what the compute element costs, there should have been a cable included.
Alan
Alan,
The pinout and connector information is provided in the TPS (Technical Product Specification) for the board.
- For the NUC Element products, you can download these documents from here: Intel NUC Element Technical Product Specifications.
- For the standard NUC products, you can download these documents from here:
Hope this helps,
