Intel® NUC Elements
Support for Intel® NUC Compute Element, Board Element and Chassis Element
77 Discussions
System crashing with SA2000M8/500G with NUC8i3BEH2 - Ubuntu 18.4
Anonymous
Not applicable
I have a NUC8i3BEH2 with 1x 1TB SATA2 HDD, 1x external 1TB SSD and 1 Kingston SA2000M8/500G SSD. My OS ist Ubuntu 18.4 LTS
When try building Android roms  with the SATA2 or the external SSD everything works fine
When trying the same job with internal Kingston SSD the system is crashing totally. It hangs, black screen and I have to push the power button to reboot.
From specs the Kingston SA2000M8 is OK.
What could be the reason for the issue ??
n_scott_pearson
Super User Retired Employee
That's an NVMe SSD. You need to be booting in UEFI mode; you can't use legacy mode. I would check with your distro provider for more information on how you need to do things differently.
Anonymous
Not applicable
That's not the solution
I have rested the BIOS to default,
Installed Linux Mint and Ubuntu 18.4 new
Checked the bootmanager = UEFI boot is working
But SSD is still crashing. Yellow LED for disk activities is on (no flashing. Maus is working but nothing else.
n_scott_pearson
Yea, but did you actually UEFI boot Linux? As I said, check with your distro provider for more information on how you might need to do things differently.
Anonymous
Not applicable
Yes, for 100% UEFI boot.
The BIOS is changed to boot only UEFI.
The linux bootmanager is showing UEFI boot.
And by the way, what do you mean with Linux Provider??
I'm using Ubuntu 18.04 and Mint 19.3. All are using UEFI boot.
n_scott_pearson
You said it yourself: Ubuntu and Mint.
Anonymous
Not applicable
Ah, OK,
I have made all test on UBUNTU and all are showing that Ubuntu is booted in UEFI mode
nuc@nuc:~$ [ -d /sys/firmware/efi ] && echo "Installed in UEFI mode" || echo "Installed in Legacy mode"
nuc@nuc:~$ if test -d /sys/firmware/efi;then echo efi;else echo bios;fi
efi
nuc@nuc:~$ ls /sys/firmware/efi
config_table esrt fw_vendor runtime-map vars
efivars fw_platform_size runtime systab
So the issue must be somewhere else.
Esteban_D_Intel
Hello harvey186,
I need to inform you that Intel does not test and validate Intel® NUC on Linux, however we know have received many different positive reports from NUC owners that are working with the unit on many different Linux distros.
Intel suggests you check your Linux distro's website and forums in the following link for peer assistance with this behavior.
Have you tried checking with your Linux* distributor yet?
Esteban D.
Intel Technical Support Technician
Anonymous
Not applicable
Yes, I have all my informations how to ensure UEFI boot from UBUNTU community.
Esteban_D_Intel
Hello harvey186,
Thank you for your response.
I understand that this behavior occurs only when working with the internal SSD.
  • Have you swapped the internal SSD for another? To see if the crashes persists.
  • For how long you’ve been experiencing this behavior?
  • Do you see any light pattern in the chassis of the NUC?
  • Does the crashes occur only under that workload?
Please run the following tool and attach the reports generated.
Intel® System Support Utility for Linux* (Intel® SSU) Download link
1.       Open the application and click on "Scan" to see the system and device information.
2.      By default, Intel® SSU will take you to the "Summary View".
3.       Click on the menu where it says "Summary" to change to "Detailed View".
4.       To save your scan, click on "Next", then "Save".
Esteban D.
Anonymous
Not applicable
    • yes -- same result
    • from beginning on with all tried OS - Ubuntu 18.4 / Ubuntu 20 / Mint 19.3 / Mint 20
    • The yellow LED in front is permanent on
    • I'm building AOSP Android rom. So, Yes
Attached the scan file
With internal SATA2 HD and external SSD all working fine. Only internal SSD is crashing
Esteban_D_Intel
Hello harvet186,
Thank you so much for your response. To ensure the top performace of the NUC, I would recommend to perform a BIOS update to the version 0083. Which is the latest version.
I noticed in the report that you are using version 077.
Please follow the steps below and check results with me:
1.     Download the Recovery BIOS (.BIO) file from the following link
2.     Copy the recovery file (*.BIO) to a USB device.
3.     Plug the USB device into a USB port of the target computer.
4.     Shut down the target computer.
5.     During boot, when the F7 prompt is displayed, press F7 to enter the BIOS Flash Update tool.
6.     Select the USB device and press Enter
7.     Select the .BIO file and press Enter
8.     Confirm you want to update the BIOS by pressing Enter
9.     Wait 2–5 minutes for the update to complete.
10. Remove the USB device.
11. Restart the computer.
Esteban D.
Anonymous
Not applicable
Hi Esteban,
thx for the information, I Have updated the BIOS but getting same issue as before. For me, it looks like the SSD is powered off will the system is working. Because the error messages are shown something like: drive not available, or write protected.
It seems that the hardware will not work with Ubuntu. So I will send the device back to the reseller and will buy me another Linux compatible barbone.
But anyway, thx for your support
Esteban_D_Intel
Hello harvey186,
Thanks for the update.
We appreciate your patience and the troubleshooting performed on your side.
In case you are interested, please check the Linux* Support for Intel® NUC
We really hope that you can resolve this behavior with your reseller, Additionally, if you would like to perform further troubleshooting on this matter, as previously stated, I would strongly recommend checking with your operating system developer for further recommendations or reported issues.
If you need any additional information, please submit a new question as this thread will no longer being monitored
Esteban D.
