Intel® NUC Elements
Support for Intel® NUC Compute Element, Board Element and Chassis Element
95 Discussions
What is the thread size on the bottom of the NUC for mounting?
DLent2
There are two screw holes on the bottom of the NUC. I want to know what screw size I need for those holes.
Thanks!
AndrewG_Intel
Hello DLent2
Regarding your inquiry, could you please confirm the following information?
1- Full Intel® NUC model:
2- Are you looking for the screw size that is needed to mount the Intel® NUC on the VESA mount?
Andrew G.
DLent2
It's the NUC 8i5, and yes those screws.
LeonWaksman
DLent2
I understand Intel sells a mount, I do no want to use that and the screws in that kit are not long enough for my needs. Therefor I need to buy screws of the same diameter and pitch but different length. What are the diameter and pitch of those screws?
LeonWaksman
You have all information in the link from my post above. You nee click on "Installation instructions" . The four screws used to attach the Vesa panel to monitor are M4 size. The two screw attached to bottom of NUC (to hang the NUC on the panel) are M3 size.
The M4 is a metric screw specifying a nominal diameter of 4 millimetres ; and standard coarse thread pitch defined as 0.7 millimetres .
The M3 is a metric screw specifying a nominal diameter of 3 millimetres ; and standard coarse thread pitch defined as 0.5 millimetres .
Leon
AlHill
In the link Leon provided, it states that the screws are m3 and m4, standard metric sizes.
Doc
DLent2
Oh my apologies I see now. Thank you!
