happy new year
i bought nuc ghost canyon last month
but one sata cable was break
where can i buy it?
sata 3 7 pin cable that attached to cpu module
No, SATA cable is not broken, it simply is not supplied with the product.
If you want to purchase one, you can do so through Micro Sata Cables (see here: https://www.microsatacables.com/intel%20nuc%20sata%2022%20pin%20sata%20drive%20fcc%20cable).
Now, I found that, with a standard double-wide graphics card (also) installed in the Ghost Canyon chassis, there is zero room to put a SATA HDD/SSD anywhere in the chassis.
this port cable was broken
is that sata 3?
which cable need i buy?
No, the connector you marked is the Internal USB 3.1 Gen 2 20-pin Header.
The SATA Data/Power header is the one I circled in yellow:
For the SATA Data/Power header, you need the cable that I included link for.
BTW, for that USB header, you can also get the cable from Micro SATA Cables. Here is link: https://www.microsatacables.com/intel-nuc-nuc6i7kyk-skull-canyon-internal-usb-3.0-header-cable-skc-1105-usb3.
I taken photo what i need refair
What name of this cable?
