Intel® NUCs
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11991 Discussions
Здравствуйте. Я приобрел NUC8i7BEH, установил windows 10( с usb флешки). Установил драйвер wi-fi, перезагрузил компьютер и теперь он постоянно перезагружается( заставки nuc не появляется, в биос по F2 зайти не могу).
crick1
Amy_C_Intel1
Hello ПМоро, Thank you for posting on the Intel® Communities. Try accessing the BIOS with these steps: Navigate to settings. Select Update & security. Select Recovery from the left menu. Click Restart Now under Advanced startup. Click Troubleshoot. Click Advanced options. Select UEFI Firmware Settings. Click Restart. These steps should take you to the BIOS screen, once there press F10 to load the defaults. If the reboot behavior does not let you follow the steps above, try the minimal hardware configuration in your Intel® NUC(one memory stick, hard driver, mouse and keyboard). Amy C Intel Customer Support Technician Under Contract to Intel Corporation
crick1
Thank you ​for advice. Bios did not work. I installed last BIOS and now it works.)
Amy_C_Intel1
Glad to hear that, ПМоро! Enjoy your Intel® NUC. Amy C Intel Customer Support Technician Under Contract to Intel Corporation
