Intel® NUCs
Do you have improvements you would like us to make on this community site? If so, we would love to hear your feedback! Click here for an 8 question survey. Thanks!
11306 Discussions
最新显卡驱动问题,导致photoshop cc2018花屏。Latest Graphics driver issues。
sjc
我的电脑:windows10,nuc6 i5,
当安装官方最新版的显卡驱动会导致photoshop cc2018花屏。当关闭gps加速功能后不花屏,但是你知道的现在photoshop必须要开启gps加速否则速度很慢。
当安装显卡驱动Driver Version: 21.20.16.4590版本时候photoshop不花屏,但是Illustrator CC 2018有轻微的花屏。
我已经确定了不是photoshop的问题。而是显卡驱动的问题。
请帮帮我,谢谢!
My Computer: WINDOWS10,NUC6 i5,
when installing the official latest version of the graphics driver will cause Photoshop cc2018 flower screen.
When you turn off the GPS acceleration, you don't have to spend the screen, but you know that now Photoshop has to turn on the GPS acceleration or it's slow.
Photoshop does not spend the screen when installing the graphics driver driver version:21.20.16.4590 version, but illustrator CC 2018 has a slight flower screen.
I've identified a problem that is not Photoshop.It's a graphics-driven problem.
Please help me, thank you!
Community Manager
Hello wowwo
Thank you for joining the community
I understand that you have problems with driver update on your system; to better assist you with your situation, I will need to check some information on your computer. Please follow these steps:
  • In the keyboard, press WinLogo key + R.
  • In the Run box please type dxdiag and hit Enter.
  • Copy all the information (Ctrl+C) and paste it here (Ctrl+V) so I can take a look.
Leonardo C.
sjc
thank you!
最新的图形卡驱动已经被我卸载了,现在安装的驱版本是22.20.16.4836,但是依然花屏。
The latest graphics card driver has been uninstalled by me and now installs the drive version is 22.20.16.4836, but still flower screen.
System Information
Time of this report: 1/26/2018, 12:04:25
Machine name: NUC
Machine Id: {F34FF150-BA03-4ADD-9706-AF41CE4A1A8D}
Operating System: Windows 10 专业版 64-bit (10.0, Build 16299) (16299.rs3_release.170928-1534)
Language: Chinese (Simplified) (Regional Setting: Chinese (Simplified))
System Manufacturer:
System Model:
BIOS: SYSKLi35.86A.0063.2017.1115.1550
Processor: Intel(R) Core(TM) i5-6260U CPU @ 1.80GHz (4 CPUs), ~1.8GHz
Memory: 16384MB RAM
Available OS Memory: 16274MB RAM
Page File: 3166MB used, 29490MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.16299.0015 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) Iris(R) Graphics 540
Manufacturer: Intel Corporation
Chip type: Intel(R) Iris(R) Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_1926&SUBSYS_20638086&REV_0A
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 8264 MB
Dedicated Memory: 128 MB
Shared Memory: 8136 MB
Current Mode: 1440 x 900 (32 bit) (60Hz)
HDR Support: Not Supported
Display Topology: Internal
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.640148,0.340344), Green(0.290539,0.580578), Blue(0.140148,0.060070), White Point(0.313977,0.329602)
Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
Monitor Name: Generic PnP Monitor
Monitor Model: VA1916w-6
Monitor Id: VSCF91F
Native Mode: 1440 x 900(p) (59.887Hz)
Output Type: HDMI
Monitor Advanced Color Capabilities: None
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_2e329e8610bbb375\igdumdim64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_2e329e8610bbb375\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_2e329e8610bbb375\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_2e329e8610bbb375\igd12umd64.dll
Driver File Version: 22.20.0016.4836 (English)
Driver Version: 22.20.16.4836
DDI Version: 12
Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 2.1
Graphics Preemption: Triangle
Compute Preemption: Thread
Miracast: Supported
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 2017/10/17 8:00:00, 64878968 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: Unknown
Device Identifier: {D7B78E66-5A66-11CF-D2F1-7300B1C2DB35}
Vendor ID: 0x8086
Device ID: 0x1926
SubSys ID: 0x20638086
Revision ID: 0x000A
Driver Strong Name: oem3.inf:5f63e534647eb659:iSKLD_w10_DS:22.20.16.4836:pci\ven_8086&dev_1926
Rank Of Driver: 00D12001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeVC1_D2010 DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_Multiview_NoFGT DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2...
Community Manager
Hello wowwo
I see your graphics driver is 22.20.16.4836 seems that the is a newer version of drivers you can download this new version on the following link
https://downloadmirror.intel.com/27412/a08/win64_15.60.2.4901.exe https://downloadmirror.intel.com/27412/a08/win64_15.60.2.4901.exe
let me know the outcome
Leonardo C.
sjc
sorry!It does so! Here is my recorded video. But I am sure it is a graphics driver problem. The same photoshop cc2018 on my other computer does not have this problem.
Community Manager
Hello wowwo
Thank you for your response and the information of the system
Could you let us know the type of video cable connection you are using?
Just to confirm the model of your Intel® NUC is NUC6i5SYB?
Leonardo C.
sjc
thank!
It's nuc6i5syh.
I use HDMI to my Display.
Community Manager
Hello wowwo
Thanks for the additional information. Let me do further research on this matter. I will be posting back when information becomes available
Leonardo C.
Community Manager
Hello wowwo
Thank you for waiting, allowed me to share with you that we were working to replicate your situation; these were the steps taken on the lab:
-we use the Intel® NUC Kit NUC6i5SYH.
- Clean installation of Windows® 10.
- Install Photoshop software.
- Update graphics drivers to .4901; with this graphics driver, we had a similar problem that you are having.
- Update graphics drivers to .4944; with this graphics driver, we did not have the problem.
You can try to update your graphics drivers to the version 15.65.4.4944, you can find that at the following link:
https://downloadmirror.intel.com/27484/a08/win64_15.65.4.4944.exe https://downloadmirror.intel.com/27484/a08/win64_15.65.4.4944.exe
Let me know the outcome.
Leonardo C.
Community Manager
Hello wowwo
I was checking your case and would like to know if you need further help. If so, please do not hesitate in replying back.
Leonardo C.
sjc
thank you! this driver no problem.
