Community
cancel
Showing results for
Search instead for
Did you mean:
治罗
英特尔nuc7i7BNH外接万兆网卡
请问,英特尔nuc7i7BNH是怎么外接万兆网卡的呢?然后现在市面上又有那几款万兆网卡可以接呢,谢谢.
如果方便的话发方案我邮箱.谢谢!
n_scott_pearson
Super User Retired Employee
First of all, I edited your query to remove your email address so that you do not receive a ton of SPAM as a result (it may already be too late; time will tell). People can respond to your query here and you will get notification of their responses being posted.
I can think of two ways that you could connect a 10Gb Ethernet controller to this NUC with the expectation of getting its full performance.
  1. Install a M.2 card that brings out the x4 PCIe lanes from the M.2 connector and exposes them in a x4, x8 or x16 PCIe card connector. A PCIe board with 10Gb Ethernet controller could then be plugged into this connector.
  2. Use a Thunderbolt adapter that exposes a 10Gb Ethernet controller on the Thunderbolt3 bus.
Hope this helps,
