Intel® NUCs
12325 Discussions
원도우 10 프로 누적 업데이트 ver 239와 amd 그래픽 카드 층돌 문제
병임000
NUC Kits NUC8i7HVK 에서 원도우 로그인 화면에서만 초록색 띠가 생겼다가
없어짐니다 ! 누적 업데이트 ver 207 부터 이런 증상이 나타나네요 !
해결 방법은 없나요 ?
LeonWaksman
In my NUC8i7HVK I did not observed any problems after updating Windows 10 to version 1903, neither in build 18362.207 and nether in build 239. I have the latest DCH driver installed - ver. 6919 https://downloadcenter.intel.com/download/28888/Intel-Graphics-Windows-10-DCH-Drivers?product=80939
To recover from this problem you may restore your Windows to the last working configuration:
  1. Press Power Button to switch NUC ON
  2. Repeatedly depress F8, you will see words: Please wait. Stop depressing F8, NUC will enter Advanced Option Menu.
  3.  Click/tap on Troubleshoot.
  4.  Click/tap on Advanced options.
  5.  Click/tap on System Restore (use a restore point recorder on your PC to restore Windows).
  6.   If prompted, click/tap on an administrator and follow the instruction on screen. Select the restore point form the list.
  7.  After few Nexts, click Finish confirmed by Yes - the restore will start.
  8.  Your PC will now restart and perform a System Restore.
  9.  When the System Restore has completed successfully, click/tap on Restart.
Hope this helps
Leon
