Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13508 Discussions
10i5FNH and Samsung SSD 870 QVO only recognized as SATAII and not as SATA III
Sebastian_04
as mentioned in the headline I bought a brand new Samsung SSD 870 QVO 1 TB and replaced my old Crucial 0,5 TB. When I restarted my NUC it went slow and when I checked with Samsung Magician it showed me that this SSD was nor recognized as SATA III but only SATA II - I checked with Crystal Mark the transfer speed and the numbers confirmed this slow connection (max 280 MB/s seq. Transfer speed - should be >400 MB/s) What can I try to get the SSD properly working? Btw. my old Crucial SSD showed Transfer speed up 490 MB/s in this NUC.
Kind Regards
Sebastian
Sebastian_04
Hello Support team,
after I checked the results of the SSU program - I decided to send back the SSD. It became clear, that the hardware of the SSD,  is defective.
BR Sebastiaan
Qute:
Der Treiber hat einen Controllerfehler auf \Device\Harddisk2\DR2 gefunden.
Fehler beim E/A-Vorgang an der logischen Blockadresse "0x0" für den Datenträger "2" (PDO-Name: \Device\00000053) aufgrund eines Hardwarefehlers.
n_scott_pearson
Super User Retired Employee
I have heard of this happening if the SATA Power/Data cable is not connected properly. You may have accidentally pulled it too hard when replacing the drive. Try reseating the cable in the connector.
Hope this helps,
Sebastian_04
Hello Scott,
just checked and tested: the same "cage" and "cable" in my 10i5FNH: Old Crucial SDD attached and connected SATA III speed - new Samsung 870 QVO will only be attached with SATA II... Both scenarios are verified with CrystalMark data....
Thank you for your idea - no I am sure that it is not related to the cable.
Kind regards
Sebastian
Sebastian_M_Intel
Hello Sebastian_04,
Thank you for posting on the Intel® communities.
So we can better assist you, please provide the following:
1. Run the Intel® System Support Utility (Intel® SSU) and attach the report generated:
  • Open the application, check the "Everything" box, and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
  • Use the option under the reply window to attach the report to the thread (Drag and drop here or browse files to attach).
2. Have you checked with Samsung* if perhaps you are missing a driver or firmware update?
3. Are you able to test this drive on another PC? If yes, what is the outcome?
Sebastian M
Intel Customer Support Technician
Sebastian_04
Hello Support team,
BR Sebastiaan
Qute:
Sebastian_M_Intel
Hello Sebastian_04,
I received a notification that this thread was marked as solved previously but the post is not shown.
Can you please let us know if you found a solution to this matter?
Sebastian M
Sebastian_04
Dear Sebastian,
after I checked my NUC 10i5 with the recommended SSU software it became clear, that the SSD had a hardware controller mistake (error). The protocol and also the Windows 10 "Windows EventViewer" showed a hardware disc error. I decided to send back the SSD to where I had bought it.
Best regards
Sebastian
Sebastian_M_Intel
Hello Sebastian_04,
Thank you for your update.
Based on that, we will proceed to close this inquiry.
If you get to have additional questions, please submit a new thread and we will gladly assist you.
Sebastian M
