Intel® NUCs
Assistance in Intel® NUC products
13314 Discussions
10i5FNH restarts after shutdown
chyvonomys
When I shutdown it from Windows 10, it turns off but then starts automatically again after 2-3 seconds.
It is only possible to shut down by pulling out the power cable during that 2-3 second period or by holding power button longer than 10 seconds.
I have tried recovering BIOS, but that did not help (ver. 0051).
This happens every time I try to shut it down.
LeonWaksman
Hi @chyvonomys
1. Enter BIOS - click on F2 when you see the Intel NUC logo.
2. Reset BIOS to default settings - click on F9 (confirm) and then click on F10 (confirm), to save default settings and exit to Windows.
3. Let the NUC fully reboot into Windows and then click Power > Shut down.
4. If you want customize bios settings, you can enter again to Bios setting to change the necessary settings.
Leon
chyvonomys
I did that after BIOS update, and tried again. NUC still starts after shutdown.
LeonWaksman
Hi @chyvonomys
It happened to me also. So I suggest that you perform BIOS update, this time using BIOS Recovery by Security Jumper  method and then reset BIOS to default settings. It worked in my NUC, so it should work for you.
Leon
chyvonomys
I already did a recovery: downloaded .cap file (0051), put it on USB flash, pulled out yellow jumper. It started countdown and recovered BIOS. But shutdown is still not working properly.
LeonWaksman
After recovery with By Security Jumper, did you rest BIOS to default settings? If not, please do it.
Leon
chyvonomys
Yes I did that right after recovery, and also did that few times on boot: F2, F9, F10.
Maybe try downgrading to 0050?
LeonWaksman
This problem (restarting), happened to me in NUC FN in both versions: 0050 and 0051, but after recovering BIOS and resetting to default it was fixed. So, it is up to you to try download BIOS, but I don't know if it will help.
However, I'm sure that this is BIOS problem (rather than Windows) and it happen after BIOS update.
Leon
chyvonomys
Thanks Leon, I'll try performing Recovery by Security Jumper again later today.
BTW when should I put jumper back? Maybe I did not perform that correctly
LeonWaksman
After you see the message that recovery was completed, hold the power button until NUC power OFF. Next, remove the Power Adapter Cable. Only now, reinstall the jumper between pins 1-2. Close the bottom cover, connect the Power Adapter, power ON the NUC and let it fully reboot into Windows.
Finally, restart the NUC, and enter BIOS to set the default settings.
Refer to page 33   in Technical Product Specification, for jumper location.
Leon
chyvonomys
I tried performing recovery with jumper removed again. No luck.
In fact even when it says recovery is complete and tells me to power off, remove power cable and reinstall jumper it is impossible to just turn off, because it restarts 3 seconds after I press power button.
Anyway this doesn't seem to be fixable just by recovering flash, as I tried F7 and Jumper methods few times already.
AlHill
I upgraded my NUC10i7FNHJA1 to bios 0051 via F7, followed by F9.  I just did a shutdown, and waited for a restart.  It did not restart.
LeonWaksman
Hi Al,
Are you aware that after resetting BIOS to default settings, the Sleep Mode is set to Modern Standby (this is the default Sleep Mode). If you are working in the Modern Standby mode, can you put your NUC into sleep from the Start Menu?
My NUC FN when is working in Modern Standby mode, can't go into sleep from the Start Power Menu. That's the reason that after resetting BIOS to default, I take care to keep the Sleep Type in Legacy S3 Standby.
Leon
AlHill
I just put the FN to sleep from the start menu, and woke it up without a problem.
Al
David_G_Intel
Apart from the above recommendations, try reinstalling the operating system and if it does not work we recommend that you contact live support for warranty options.
Best regards,
David G
Intel Customer Support Technician
