Community
cancel
Showing results for
Search instead for
Did you mean:
HHube1
192khz 24Bit on NUC7i5/7i7 finally solved?
Hello!
Is the Problem with 192khz and 24Bit solved?
I can only change to maximum 176400 Hz and NOT 192000 over HDMi for my Denon Receiver.
(The receiver play 192khz with another computer)
When the Problem is finally solved which driver must i use?
thanks in advance
Community Manager
Hello Huberhansel
We received your inquiry and I understand that you are looking for information for an audio problem. Please accept our apologies for any inconvenience this may be causing. We will be more than happy looking for a solution.
Let me investigate that problem in the meantime could you provide us with the following information?
  • The Intel® System Support Utility for Windows* report on the following link:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
  • What application are you using to set the 176400 Hz audio setting?
Please attach the files to the thread
Leonardo C.
Community Manager
Hello Huberhansel
I was checking your case and would like to know if you need further help. If so, please do not hesitate in replying back.
Leonardo C.
