Intel® NUCs
Assistance in Intel® NUC products
13309 Discussions
2070 Super Mini in NUC9i9QNX
hmw2
Looking to buy the Nuc Ghost extreme and wondered if the new Zotac 2070 Super Mini will fit in? I assume so... but can’t find anything to confirm. Here is a link to the card:
https://www.zotac.com/us/product/graphics_card/zotac-gaming-geforce-rtx-2070-super-mini
Thanks all
LeonWaksman
Hi @hmw2
This Graphics Adapter wasn't Wasn't validated by Intel or Zotac for NUC9i9QNX (although it still may work on it, just it wasn't tested). I suggest that you check the list  of Intel and/or Manufacturer verified components for NUC9i9QNX.
Following the above list should assure the compatibility.
Leon
BHarr8
Valued Contributor I
The smallest 2070 Super cards are supposed to fit but when I tried the clearance was so bad that I relented and went with a 2060 that was about .5 inches shorter. Its tight, but acceptable.
I don't think this is going to matter though looking at the Nvidia gen 3000 cards. I suspect that even low end cards will outperform the 2070. The performance : Watt ratio is also much better so getting 2080 performance for 2060 power consumption should be more or less accurate, and cheaper than a 2070.
Just need to wait for the smaller builds to come out, should be before the year is up.
n_scott_pearson
Super User Retired Employee
There is technically less than 8" for the card and most of the dual-fan cards are just slightly longer than that. I also chose to go with a single-fan 2060 card instead; the theory being that 2070 may require two fans to adequate cool it.
hmw2
Thanks for sending that Good to know - and can monitor for updated ones being added.
AlHill
I have installed a Zotac 1660 Ti with dual fans.  It fit nicely without any issues.  Now, I have not powered up yet (waiting for memory and storage), but I expect no problems.
