Community
cancel
Showing results for
Search instead for
Did you mean:
RFail
30 seconds after shutdown before removing power from the system ?
I've read this instruction on the optane document given with my new NUC7i3BNHX1. What does it mean ? What will occur if this instruction is not followed ?
Thanks for the answer.
Best regards.
Community Manager
Hello r_faillot,
Thanks for posting in our communities.
We would like to check the document you're referring to. Is this a physical manual, or is it an online or digital file? If so, please share with us the name of the guide or the link.
Eugenio F.
RFail
Community Manager
Hello r_faillot,
Thanks for taking the time to scan the document and share it with us.
The "CAUTION! Please allow 30 seconds after shut down before removing power from the system" disclaimer seems to be a general advise for electronic devices. The idea is to allow the components (circuits, capacitors, etc). to discharge in order to avoid damage.
However, it'll be better to engage our community. They might be able to provide better recommendations for your device.
Eugenio F.
Community Manager
Hello r_faillot,
We were checking this case on noticed we haven't heard from you in while.
Please let us know if there's anything else we ca help you with.
Eugenio F.
