Intel® NUCs
Assistance in Intel® NUC products
13308 Discussions
8th Gen NUCs audio jack socket
FredFrin
Hi! I've been looking for an upgrade to my ageing NUC5i5MYHE. That was chosen specifically because it had dual display ports - I run Linux with dual display, which seem to run best with two identical outputs for the monitors.
I have just pre-ordered a NUC8v7PNH - small form factor - high variant for extra HDD (would really be nice if the bay height was increased to accomodate higher 15mm HDDs), as it has dual HDMI outputs. But I just noticed this model has the 3.5mm audio jack socket removed,  see https://simplynuc.com/8v7pnh-full/
Why? The NUC8i7BEH for example still has it. I want to drive my Creative (Gigaworks T40) speakers via 3.5mm input.
So my qu is: what is the recommended workaround for this? Intel must have something in mind when they just removed this. I would prefer solutions that do not require aditional power supply (such as HDMI splitters).
powerarmour
Valued Contributor II
Just use a USB sound card/dongle, easiest workaround for 3.5mm jack support.
powerarmour
