I have a Intel Nuc with CPU 10710u CPU.
On BIOS Setup, Cooling Custom option.
It can turning the Minimal Fan Duty cycle (%).
Does it possible to add on option to limited the Max Fan Duty cycle(%)? It is reasonable request.
Maybe the Max Fan Duty cycle must large >= 30% (The same as Fix Fan control).
Hi @HPBird
1. Yes, it can be done if you set in BIOS Cooling the Fan Mode to Custom. See the attached image for the settings in this mode: Fan Off capability - Disabled, Processor 60, 30, 2, CPU VR 60, 30, 2. This setting will set your fan RPM to ~ 1750.
2. You may try other settings also (still the fan should be silent): 70, 40, 2 and 60, 40, 2 respectively. This setting will set your fan RPM to ~ 2200.
Leon
I agree that the implementation of a smoothing algorithm in the EC would allow temperature spikes to be dampened and avoid over-compensating with blower speed. In fact, I already suggested this to the NUC development team (though I may have been too fancy in my suggested implementation)...
I will follow up with the team...
Hi Leon,
Sorry ..., your setting, I don't think it can limit the max Fan Duty cycle(%) when CPU heavy loading ...
Hi ...S,
Yes, I guess, it might need to implement/Improve the EC feature.
Because Intel NUC always have a Fix Fan Duty (%) ... It have already tell USER, The feature can be improvement.
Current, my setting is still keep on Fix Fan Duty (%), But I hope it can be more smart integrate into Custom Option.
HPBird
Hi Intel,
There seems have a EC issue, I think, the request improvement is a chance to included
