Intel® NUCs
Support for Intel® NUC products
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11870 Discussions
Add a switch button
edeun
Do you have a solution to deport the on / off button of the Intel Nuc C8i5beh.
I was advised to connect a switch to on pins 6 and 8 of the front panel header.
Is this the right solution because I'm afraid of short-circuiting my mini computer!!
I accept the best solution to be able to install a switch on an arcade terminal without having to touch the Nuc Power button which is inside the arcade terminal thank you
Ps : I would like to thank Mr. Léon who offered me this solution.
n_scott_pearson
Super User Retired Employee
You were advised correctly; an external (single pole, normally open) power button should be connected to pins 6 and 8 of the Front Panel connector. Pressing the button shorts (connects) the control pin (6) to a ground pin (8).
This is documented in the BE NUC TPS, which you can download through here: Intel NUC Technical Product Specifications.
Hope this helps,
LeonWaksman
Hi @edeun
I confirm, you may use the external switch, shorting between terminal 6-8 on the Front Panel Header, however this should be momentary switch. This switch depressed to at least  50 ms, signals the NUC to switch ON and next time to OFF.
Leon
