Intel® NUCs
12304 Discussions
After upgrade Win 11 no more keyboard on nuc 8i7 beh
Jeff69
I have an nuc 8i7 beh. Windows purposz an upgrade to win 11. After an upgrade without errors I have thé home screen but I can't log. No keyboard, no mouse ...
Please could you Help me ?!
JosueO_Intel
Hello Jeff69,
Thank you for posting on the Intel communities. In order to have a better understanding of the issue, please share with us the following information:
  1. Are the peripherals wired or wireless?
  2. Have you tried using a different mouse and keyboard?
  3. Can you access the BIOS? If so, does the mouse and keyboard work on it?
Josue O.
Jeff69
Hello Josue O.,
Thanks for your response. I have tested different mouse and keyboard wired or wireless, usb2 or usb3 without sucess!
I can access to BIOS and Keyboard and Mouse work lilke a charm !
The Windows 11 Recovery Menu too !
But i can't access to Windows 11. The windows mode without failure d'on't work . I can't login !
I have upgraded my BIOS to version the last version and it's the same result.
Could you help me please ?
JosueO_Intel
Hello Jeff69,
Thank you for the information provided, in this case, please let me know if you have tried performing a clean installation of the OS using a fresh copy of Windows*.
Josue O.
Jeff69
I use BitLocker,
I need to backup my drive with an external tool before trying a new install.
I was hoping to find a simple solution.
Thanks for your help.
JosueO_Intel
Hello Jeff69,
Thank you for the information provided, in this case, I will check the issue internally and try to find a solution without performing a new install. I will post back soon with more details.
Josue O.
JosueO_Intel
Hello Jeff69,
We have performed a lab trying to replicate the issue, however, we didn't encounter the same issue with the keyboard and mouse.
Since we were not able to replicate the issue, our recommendation is to back up all the information and try reinstalling the OS.
You can also try using a different SSD, install the OS, and test if the keyboard and mouse work without any issues. Also, you can try restoring the unit with restore points.
Please let me know if you are able to perform the steps and the results.
Josue O.
Jeff69
I will do the tests this weekend and get back to you.
JosueO_Intel
Hello Jeff69,
Sure, we will wait for you to perform the tests.
Josue O.
JosueO_Intel
Hello Jeff69,
Were you able to perform the steps provided?
Let us know if you still need our assistance.
Josue O.
Jeff69
Hello Josue_O_Intel,
I installed my NUC from the scratch and everything works fine!
Thank you for your help and your responsiveness.
Best regards
JosueO_Intel
Hello Jeff69,
I am glad to hear that the issue is now solved and everything is working fine.
Josue O.
