Intel® NUCs
12330 Discussions
Another NUC11PAHi7 with fan running during sleep mode.
da6
NUC11 sleeps and wakes when it is supposed to, but the fan never shuts off. I assume it has modern standby configured by default.
All drivers are current.
I am not the only one reporting this problem. Is there a solution other than reverting to legacy S3?
Dave
Windows 11 Home version 21H2 Build 22000.376
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"Intel Corporation"
BIOS Mode:"UEFI"
BIOS Version/Date:"Intel Corp. PATGL357.0041.2021.0811.1505 , 08/11/2021 12:00 AM"
CD or DVD:"Not Available"
Embedded Controller Version:"3.3"
Platform Role:"Desktop"
Processor:"11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz , GenuineIntel"
Secure Boot State:"On"
SMBIOS Version:"3.3"
Sound Card:"Realtek High Definition Audio"
Sound Card:"USB Audio 2.0"
System Manufacturer:"Intel(R) Client Systems"
System Model:"NUC11PAHi7"
System SKU:"RNUC11PAHi7000"
System Type:"x64-based PC"
- "Motherboard"
BIOS:"PATGL357.0041.2021.0811.1505, INTEL - 29"
Caption:"Motherboard"
Chipset:"Not Available"
Date:"08/10/2021 05:00 PM"
Install Date:"Not Available"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Model:"Not Available"
Part Number:"Not Available"
PNP Device ID:"Not Available"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Product:"NUC11PABi7"
Serial Number: REDACTED
Status:"OK"
Version:"K90104-305"
da6
I turned off BitLocker.
Rebooted in SAFE mode.
Added the PlatformAoAcOverride registry key.
Rebooted in normal mode.
Powercfg shows S3 is available. S0 is not available. PC enters sleep w/o fan running. Success!!
With the NUC11 I lose the amber flashing power button in sleep mode. The BIOS indicates this is only available with Modern Standby S0. It blinks the blue LED in sleep.
I was curious about BitLocker and went to see if it was possible to re-enable it. The control panels are gone. A search returns nothing. No big as I have never used it on prior PCs anyway.
I found this link that discusses BitLocker in Win 10.
https://www.tenforums.com/tutorials/145880-how-check-if-device-encryption-supported-windows-10-a.htm...
It says Modern Standby support is required for BitLocker. Maybe explains why the function seems to be gone now.
I’m curious to know what would have happened had I not turned off BitLocker (and decrypted) prior to disabling Modern Standby.
If this was a new build I definitely would have experimented. As it is I have too much time invested in setting the NUC to try it now.
Thanks all , especially Leon, for your help.
Dave
BHarr8
Valued Contributor I
It happens with the NUC11PHKi7C as well on both Windows 10 and 11.
It does not happen all the time but once it starts the fan cycles on and off over and over and the NUC itself is very hot to the touch.
Often times when this happens it also becomes impossible to wake the device and it has to have the power plug pulled to force it to shut down.
da6
Fortunately my NUC does not display the serious issues you describe. It sleeps when it is supposed to and wakes immediately.
I have experimented with the BIOS settings a bit. I found if I set the minimum duty cycle to a low number, like 10%, I cannot hear the fan run when sleeping (but I’m certain it is). However doing this seems to disrupt other fan behavior and I will occasionally get very high, short duration fan speeds for no apparent reason.
Alberto_R_Intel
da6, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
Is this a new Intel® NUC?
When did you purchase it?
Was the fan working fine before?
When did the issue start?
Did you make any recent hardware/software changes that might cause this problem?
Which Windows* version are you using?
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91...
Albert R.
da6
Hello Alberto,
This is a new NUC11PAHi7 purchased in December 2021.
The fan running while sleep has always been an issue.
No hardware problems that I am aware of. The PC will enter sleep mode normally (flashing LED, etc) but the fan never shuts off. It continues to run at the same speed as when awake.
I am running Windows 11, fully updated.
This is a home-based PC only.
The ssu report is attached.
Thanks for your assistance.
Dave
LeonWaksman
Hi @da6
Please read Intel® NUC NUC11TN and NUC11PA's Fan Continues to Run While in Sleep Mode
You may try to revert the Sleep Mode to Legacy S3 Standby  by adding the registry key as advised in the linked Microsoft Document.
Leon
da6
Leon,
Thanks for linking that Microsoft document. The entire docs directory is a treasure.
I am aware of the registry tweak for S3, but I have not tried it. It may turn out to be the best solution.
Dave
LeonWaksman
Hi Dave,
I've never liked the Modern Standby and in my Gen 10th NUC, changed to Legacy. However,  I did this in BIOS settings, since the Legacy S3 Standby is still supported here. But this is not the case in your NUC. I suggest that in order to protect the Windows, before applying the registry tweak, set the boot mode to SAFE. Only after applying this registry change and rebooting in SAFE mode, set back to NORMAL.
Hope this helps
Leon
da6
I’ve read that switching between modern standby and S3 requires OS reinstallation. Does the safe mode procedure avoid this inconvenience?
LeonWaksman
Exactly. I've changed the Sleep Mode few times already, always in SAFE mode. No needed reinstall Windows.
In order to set  Windows to SAFE mode:
  1. While in Windows, press Windows key + r. Run msconfig
  2. Chose Boot tab and check Safe boot.  Reboot your system.  Windows will boot in SAFE mode.
after changing the Sleep Mode:
  2. Chose Boot tab and uncheck Safe boot.  Reboot your system. Windows will boot in NORMAL mode.
Leon
da6
Thanks again.
I will try this option over the weekend.
da6
Leon,
While attempting to set SAFE mode I received a warning that BitLocker is enabled and I will need to provide a recovery key at boot. I did not know Win 11 HOME enabled BitLocker by default.
I do have the keys printed. Is this something that I need to be concerned with?
Dave
BHarr8
Having dealt with bitlocker nightmares more than a few times I can honestly say that for 99% of users, it is more trouble than its worth.
Disable it, allow the decrypt and then never deal with it again.
LeonWaksman
Hi Dave,
I've never used  Bitlocker encryption. So, better before starting this procedure, switch the Bitlocker OFF and decrypt the drive How to Remove Bitlocker Encryption In Windows 11 | Turn Off Bitlocker
If you want, later you will be able to reenable it again.
Leon
da6
Dave
BHarr8
The information in this thread accidentally fixed another bug that appeared in the NUC11PHKi7C.
Prior to trying to fix the overheating while sleeping problem there was also a bug where it was impossible to change power plans.
Now that I have run the S3 standby fix, I have also gained access to modifying power plans.
