Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13487 Discussions
Arc A770 - NUC extreme compatibility
SamRyan
Will the arc A770 be compatible in the NUC 11 and 12 extreme? (Beast and dragon canyons).
Seems like the cards would fit perfectly into both systems.
Also for the RGB connector to USB header, where would this be located to run the connector?
Interested in getting this card
Chi_Intel
Hello S_Ryan
Thank you for posting on the Intel®: Arc communities.
This is a great question. Let me go ahead and do some research about this concern and how this configuration may require.
Please let me know if you find this information useful or if you have any other questions.
Chi C
Chi_Intel
Hello S_Ryan
We like to point out the compatibility tool for this situation, this actually will help you have a reference if you want to know about validated compatibility or technical details for a specific configuration or pairing. this is a recommended source to check
https://compatibleproducts.intel.com
The add-in car limitations for Beast and Dragon are L:300mm x H:131mm x W:39mm and 375 Watts
You also can check the ARK site to know the technical information or details about a specific product.
The physical dimensions of the Intel Arc A770 and A750 Limited Edition graphics cards are as follows: Width: 29cm, Height: 13cm, Depth: 4.3cm
Remember,  for the dimensions of other cards check directly with the manufacturer.
Please let me know if you find this information useful or if you have any other concerns.
Chi C
SamRyan
Hi Chi
Thank you for replying. I have seen a few videos where customers have fit the card in.
Can you advise where the USB headers are situated in the NUC? I am not sure and cannot find a manual that locates the headers
Chi_Intel
Hello S_Ryan
Please let me know if you find this information useful or if you have any other question.
Go to the product specification (link below) then select your model. you will be able to download a PDF with the system specs info.
Technical Product Specifications for Intel® NUC Products
For example: https://www.intel.com/content/dam/support/us/en/documents/intel-nuc/NUC11BT_DB_TPS.pdf
This model PDF NUC 11 Extreme.
On Pages 22 and 36 you can find the information about the USB headers in the boards.
You can read this other article to understand more about the USB heathers
Onboard USB Header Information for Intel® NUC
Chi C
tindallj
Chi C,
I believe the question is how do you connect the 1.25mm PicoBlade USB 4 pin connector in the NUC 12 Extreme to the USB 2.54mm 9 pin female USB connector that comes with the ARC A770. There doesn't seem to be a cable that supports that conversion directly.
SamRyan
Could you connect an adapter from the 20 pin USB 3 header on the motherboard to the 9 pin for the GPU cable?
tindallj
I'm about to find out. I ordered a 4 pin Picoblade cable with 2.54mm connectors on the end. I'm going to bridge it to the cable that comes with the NUC. The cable only uses D+,D-, and ground.
SamRyan
Interested to see the outcome
SamRyan
tindallj
So far it's not working, but I haven't opened the NUC back up to see if my cable came apart. It still says no GPU is present when loading the RGB software. I'm having other Serial port errors, so I may have flipped the wires.
SamRyan
**bleep**.
Is is possible to use a USB 3 20 pin to USB 2 9 pin adapter and connect to the header on the NUC compute element board?
Chi_Intel
Hello to all
This is a very specific detail about the configuration. Let me go ahead and do some research about this concern and how this integration may result considering the RGB  and USB connectivity.
Chi C
SamRyan
Hi Chi,
Any update from your end?
Chi_Intel
Hello Everyone,
thanks for your patience we have some updates.
By reviewing carefully the request about the Intel Arc A770, It will be compatible with NUC Dragon canyon,  nevertheless, the RGB connector isn't compatible, so the Card will be properly detected/install to the PCI ports and able to be detected by the system but with no addressable RGB.
There are plenty of NUC models and form factors so please always remember to consider the product dimensions and compatibility in the compatibility tool https://compatibleproducts.intel.com
Chi C
Chi_Intel
Chi C
Chi_Intel
Hi @SamRyan
Please let me know if you find the information useful or if you have any other questions.
Chi C
SamRyan
Thanks Chi.
So the gpu will fit, but the RGB controller won’t work, even with an adapter to the usb 3 header.
Will they still light up without being able to be controlled?
Carlos_L_Intel
Hi @S_Ryan
Thank you for your question. Let me make sure about this information and I'll get back to you shortly.
Carlos L.
Carlos_L_Intel
Thank you for your time. In this case, the RGB light will light up, however, you will not be able to control them without the cable.
Carlos L.
SamRyan
Thanks Carlos. Looking forward to trying one out in my Beast Can.
