Intel® NUCs
11782 Discussions
Audio Problem on my NUC8i7BEH (Win10 Pro 64 bit) - It’s broken up (silence for 1 second and after it continue to play)
DCol1
I need of a solution at my problem. Please.
I reinstalled Realtek driver (completely disinstalled and after reinstalled).....Device Manager says it is all ok, Drivers works correctly, but audio is interrupted very often. I generally hear sound by my bluetooth stereo......
so at the beginning I thought it was a bluetooth problem.....after i tried by front jack with some normal hearphone and same problem....so I understood that it was an audio driver problem
I can say that this problem was not there when I started using my NUC, the problem appeared later. After many days the problem seemed to have solved itself and the audio worked well again.
But later it broke again. Now I have this problem for a long time and I do not know how to solve it.
Some idea?
before trying to do a factory reset I would like to try other ways. because I'm still not sure it's a hardware problem.
