Hello
I just install a NUC11PAHi5 with Windows10
Everything works fine except the Realtek(R) Audio sound output (Jack 3.5)
the sound does not come out instantly
the beginning of a sound is not reproduced (typically 100ms)
the problem disappears when the Sound settings are opened to the playback tab
Did you notice the same thing? Is there a way to fix it?
Thank you
FR4, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this scenario, we just wanted to confirm a few details about your system:
Is this a new Intel® NUC?
When did you purchase it?
Was the audio feature working fine before?
If so, when did the issue start?
Did you make any recent hardware/software changes that might cause this problem?
Which specific Windows* version are you using?
Albert R.
Hello sir
Thank you for considering my problem
yes it is brand new
I bought it three weeks ago
She's always had this flaw.
The problem started on day one.
Negative
Windows 10 21H2 look at the attached file
At home
See attached file
The temporary solution I found is to permanently open the sound configuration window in the playback tab and there, the sound starts instantly
Sincerely
Hello FR4, You are very welcome, thank you very much for providing that information and the SSU report.
According to the information in the SSU report, we can confirm that the latest BIOS version for your Intel® NUC, which is 0042, is currently installed in your machine:
https://www.intel.com/content/www/us/en/download/19694/bios-update-patgl357.html?wapkw=nuc11pahi5
Besides that, please make sure that Intel® Chipset driver version 10.1.18793.8276:
And the Intel® Management Engine drivers are currently installed on your machine, version 2040.100.0.1029:
And then, please install the Realtek driver version 6.0.9247.1, which is the latest, once you get the chance, let us know the results:
Albert R.
Hello Albert R.
The four points have been checked
BIOS is Ok 0042
Intel® Chipset Driver Version 10.1.18793.8276 Reinstalled
Intel® Management Engine drivers version 2040.100.0.1029 reinstalled
Realtek driver version 6.0.9247.1 is already up to date
After reboot the problem is the same!
I am disappointed
See the attached file for my temporary solution This window is permanently open and it's Ok for the sound
Has another user noticed this problem? Can you test it on your machines? What can I do ?
Thank you sir
Hello FR4, You are very welcome, thank you very much for sharing those results.
We are sorry to hear the issue persists after trying the troubleshooting steps provided previously. In order to answer your questions, we will do further research on this matter, as soon as I get any updates I will post all the details on this thread.
Albert R.
Hello thank you for your reply
I'm looking forward to you bringing more information on this topic...........
Hello FR4, You are very welcome. I just received an update on this matter.
While we are still working on this case, we just wanted to confirm:
You mention you can play an audio track but the actual audio comes out of the device typically 100ms after you hit play. Is this correct?
This issue, does it happen only on the Realtek audio (3.5mm)?
What audio software/application are you using? local file, internet: youtube?
What brand/model of speakers are being used? Speakers, Headphones.
When the audio plays back, does it start from the beginning? Keep in mind, 100ms is equivalent to 0.1sec
Based on the SSU, we can confirm that you have a webcam (Iriun webcam), just to make sure, was the camera removed for testing, do you have the option to try that?
Albert R.
FR4, I've noticed the same problem with my new NUC11PAHi5, running Windows 11. It is most noticeable when Windows sounds the alert when a new notification comes in, or there's some other warning. The start of the sound is clearly clipped.
I have no suggestions for fixing it and will be following this thread. Just wanted to let you know you're not alone!
Hello, here are answers
Affirmative that is correct
All short sounds of windows notifications are truncated and therefore inaudible because too short. Typically the attached file listen to it.
However when the sound exceeds approximately 100ms then during 8sec the problem no longer exists the following sounds come out instantly and after 8sec of inactivity the sound card deactivates again
Exactly only on the Realtek audio (3.5mm)
when I use a usb sound card (see the attached file) there is no fault as on my old NUC5I3RYH which works perfectly
the result is the same regardless of the source
the result is the same regardless of the loudspeaker I tried several
negative, it does not start again at the beginning because a part is cut off
Iriun webcam has been removed for the test and it’s equal
Thank you for dealing with this issue, but I’m not alone in seeing it.
Thank you DaveF for reporting
Hello
I'm still investigating for my part and I found something interesting.
The problem is not hardware but software. It's a driver problem.
I changed the driver file 'RTKVHD64.sys' by a Windows 7 file retrieved from another PC then rebooted = It works !
see attached file (1- and 2-)
The file is loaded at each boot and it's ok except when we cut the power of the NUC.
At the next boot it's dead, the sound card is not connected anymore. See attached file (3-)
I also attach the SYS files if you can understand something.
See with Realtek for new drivers compatible with the NUC11PAHi5.
FR4, Thank you very much for letting us know those details.
We will continue with our research on this matter. As soon as I get more information I will post all the updates on this thread.
Albert R.
Hi FR4,
We are still working on this issue, currently trying to replicate it. I will get back to the community as soon as I have an update.
Ronny G
Hi Ronny G
OK for the news I wait patiently hoping for a update
thank you
FR4
Hi @FR4
We tried to replicate the issue that you reported, I even asked my peers for help but none of us could really experience this audio issue.
I would recommend two options at this point: 1) Fresh Windows* installation as a final test and/or 2) Product replacement.
We don't process warranty orders via the community due to security/privacy concerns, so I would recommend that you visit the following website and look for the best option to reach back to us https://www.intel.com/content/www/us/en/support/contact-intel.html#support-intel-products_98414:9841...
Ronny G
Thank you for your proposal to take back/exchange the NUC/reinstall Windows10 but no, after many tests I found a solution that works perfectly and that suits me.
This combination is operational after rebooting the NUC and especially after cutting the power supply and rebooting.
For those who are interested, here is the procedure:
In the folder : C:\Windows\System32\drivers rename the file RTKVHD64.sys because you will not be able to delete it.
Copy the attached file with the same name into this folder.
Reboot the NUC and it's ok.
The attached file alone solves the problem no need to downgrade the whole Realtek driver
Its version is 6.0.1.7564 of 2015/07/24 05:44
See the screenshot.
I specify that I do not use 'HD Audio Driver for Display Audio' it is disabled at home and therefore I do not know its behavior following this trick.
You can consider the problem as solved at least for me.
You can close the thread
I just hope that the next Realtek driver updates will not forbid this solution.
"I found a solution that works perfectly and that suits me.", perfect, excellent, it is great to hear that you were able to find the solution for the audio problem now the Intel® NUC is working properly.
Thank you very much as well for taking the time to share the steps to fix this issue, we are sure they will be very helpful and useful for all the pers looking at this thread.
Any other inquiries, do not hesitate to contact us again.
Albert R.
