Bought NUC Mini PC for my son's distance learning. After few months, he can't turn on his PC and showing "Automatic Repair. Your PC did not start correctly". And whichever option we choose/press, it will go back to the same message "Automatic repair...".
Any suggestion how to fix this? Have been reading suggestions online but nothing worked so far. School is starting tomorrow so any help will be appreciated. Thanks!
Hi @Me_intel
- Try to boot in Safe Mode from Command Prompt. The Command Prompt can be reached from Advanced Option Menu:
- Press Power Button to switch NUC ON
- Repeatedly depress F8, you will see words: Please wait. Stop depressing F8, NUC will enter Advanced Option Menu.
- Click/tap on Troubleshoot.
- Click/tap on Advanced options.
- Click on Command Prompt
- In the Command Prompt write the following command: bcdedit /set {default} safeboot minimal and press enter to execute this command
- Close the Command Prompt window by clicking the X in the upper right corner of the Command Prompt window.
- Select Continue and sign in to Windows
- While in Windows, press Windows key + r. Run msconfig
- Chose Boot tab and uncheck Safe boot. Reboot your system.
Leon
Will try this out and keep you posted. Thanks Leon.
