Intel® NUCs
12341 Discussions
BIOS bug NUC5I5MYBE?
GerKel1
I encounter another issue with the latest BIOS update for NUC5I5MYBE (058):
Under the Advanced -> Power tab there are three presets for Primary Power settings: low power, balanced and max performance where max performance is the default.
If you choose 'low power' the nuc will always boot as soon as it gets powered (gets connected to wall plug) without the power button beeing pressed totally ignoring the 'After Power Failure' <stay off> setting.
If you change to one of the other presets for Primary Power Settings the NUC will stay off after beeing connected to power outlet till you push the power button.
Is this intended or just another bug?
Esteban_D_Intel
 Hello GerKel1,
I need to inform you that due to this product being discontinued, Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help.
You may also find the Discontinued Products website helpful to address your concern.
That being said,keep in mind that this thread will no longer be monitored by Intel.
Esteban D.
Intel Technical Support Technician
