hello, after a bios update from 57 to 59 version, on a NUC7PJYH, it is no more possible to use any linux partitions. the downgrade is not allowed by the usual ways. might a silent jumper downgrade work in a similar case? thank you in advance.
yes, Leon, thank you. with the 60 version, the problem is solved. it is now possible to reach and work with linux partitions. thank you for your kind help and attention.
Hello jmmantel,
In this case, I would like to let you know that for security reasons the system (NUC itself) does not allow a BIOS downgrade and this is to avoid damages to the unit (software and hardware).
Try to force a BIOS downgrade can end up with permanent damage to the NUC and this could not have a solution and/o fix, that why I do not recommend you to try it.
Deivid A.
thank you, deivid, for your reply. but what could i do if the linux systems, and all systems on live-usb keys, cannot be reached since the bios update? it seems that it is a bios bug in the bios last version, which is no more available on the download intel pages. the 57 version worked fine. but the problem occured in the 58 and 59 versions. here is a post on this topic.
Hello jmmantel,
I do apologize for the inconvenience that you are experiencing with Linux operating system. In this case, since a BIOS downgrade is not possible I recommend you to get in contact with us directly to check the warranty options and ask for a replacement.
You can use the link that works better for you:
US Canada: https://www.intel.com/content/www/us/en/support/contact-support.html#@11
Europe, Middle East, and Africa: https://www.intel.com/content/www/us/en/support/contact-support/emea-contact.html
Asia-Pacific: https://www.intel.com/content/www/us/en/support/contact-support/apac-contact.html
Latin America: https://www.intel.la/content/www/xl/es/support/contact-support/lar-contact.html
Deivid A.
Hi @jmmantel
New BIOS version 0060 was released. It suppose to fix the Linux boot problem. So, try it.
Leon
