NUC (windows 10) is connected to 4K LG TV and i have to modify the aspect ratio in intel graphics setting (3840x2160) in order for the display to fit the display.
why is it not done automatically?
You should have a setting on HDMI for Picture size on the TV that says"bit by bit" or "just scan" or something like that. If 16:9 does not fit properly. also set 16:9 in the graphics settings
Mmm, nuc is replacing another pc connected to tv, and aspect ratio was handled properly by the graphic card (same 4k resolution).
I kept the same picture settings on tv.
Sorry for the late response.
Yes i have updated nuc to the latest firmware and drivers (via Intel® Driver & Support Assistant).
TV is also updated to latest drivers.
Here are the graphic properties
Graphics Intel® Iris® Plus Graphics 655
Adapter Compatibility Intel Corporation
Video Processor Intel® Iris® Plus Graphics Family
Resolution 3840 x 2160
Bits Per Pixel 32
Number of Colors 4294967296
Refresh Rate - Current 60 Hz
Refresh Rate - Maximum 120 Hz
Refresh Rate - Minimum 23 Hz
Driver Provider Intel Corporation
Driver Version 24.20.100.6286
Driver Date 8/15/2018
Adapter DAC Type Internal
Adapter RAM 1.00 GB
Availability Running at full power
Status This device is working properly.
Location PCI bus 0, device 2, function 0
Device IdPCI\VEN_8086&DEV_3EA5&SUBSYS_20748086&REV_01\3&11583659&0&10
