Intel® NUCs
Assistance in Intel® NUC products
13297 Discussions
BOXNUC8i7HVK2 Hades Canyon BIOS Deep S4/S5 setting keeps reverting to OFF
MBuri1
BIOS setting for "Deep S4/S5" keeps reverting to OFF. It works one reboot after setting it to ON, then next reboot it is OFF again. (BIOS version is the latest: 58).
We need to turn off the power from the thunderbolt ports, otherwise our connected HMD will not turn off and stays on. Without DeepS4/S5 this is not possible.
Would be very nice to have this issue fixed!
Wanner_G_Intel
Hello MBuri1,
Thank you for submitting your question on this Intel® Community.
To better assist you, we would like to gather more information about your system configuration.
  • Please generate a system report with the Intel® System Support Utility (Intel® SSU) and attach it to this thread.
  1. Intel® SSU Download link
  2. Open the application and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  3. Click on the menu where it says "Summary" to change to "Detailed View".
  4. To save your scan, click on "Next", then "Save".
  • Are date and time values in BIOS accurate after rebooting the unit?
  • Do other BIOS settings show the behavior reported on this thread?
Wanner G.
A Contingent Worker at Intel
MBuri1
Yes the date and time values are accurate after rebooting the unit. As far as I know the "Deep S4/S5" setting is the only one showing this behaviour. Other settings are saved correctly.
I've attached the SSU output
Wanner_G_Intel
Hrllo MBuri1,
Thank you for your response.
  • Try loading BIOS default settings first.
1. Press F2 during boot to enter BIOS Setup.
2. Press F9 to set defaults.
3. Press F10 to save and exit BIOS.
  • Then, enable DeepS4/S5 and check if it remains enabled after rebooting the unit multiple times.
  • If the issue persists, please let us know so that we can do further research.
Wanner G.
MBuri1
Hello Wanner,
I've tried but still the same issues unfortunately. Seems like this particular setting is not stored permanently and is lost after powering off once. I can remember that this setting was missing when we bought the NUC, I had to update the BIOS first to have it. So maybe it is still not added to the settings which are actually stored in memory?
Thanks for the help and quick responses so far.
Maarten
LeonWaksman
Hi @WannerG_Intel​ ,
I can confirm Maarten findings. Tested on my NUC8i7HVK and the DeepS4/S5 is also disabled after reboot. Did you checked this in your lab?
Leon
Wanner_G_Intel
Hrllo MBuri1, LWAKSMAN
Thank you for your input.
We will do further research and update this thread as soon as possible.
Wanner G.
Wanner_G_Intel
Hello MBuri1, LWAKSMAN
Thread update.
We would like to gather more details about your units. We have sent you a private message requesting some information about your Intel® NUC kit NUC8i7HVK.
Please let us know if you receive the message and reply to us at your earliest convenience.
Wanner G.
Wanner_G_Intel
Thank you for providing us with the information requested.
We are doing further research about this behavior. We will update this thread as soon as possible.
Wanner G.
Ronny_G_Intel
Community Manager
Hi MBuri1, Leon,
We have replicated this issue and filed a bug report that is being addressed by the product team, I cant tell you when a fix will be ready for this issue but I will keep you posted.
Bug report number is 2209673523 so I will be closing the case that was created for this community incident and will keep an eye on the bug report.
Ronny G
