Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13495 Discussions
BXNUC10I7FNH cannot output the resolution of 5120x1440.
Nantoka
I use the monitor DELL U4919DW. But my NUC cannot output the resolution of 5120x1440.
NUC outputs the maximum resolution is 3840x1080.
How can I use 5120x1440 resolution?
Windows 10 intel display driver version is 26.20.100.7755, driver date is 2020/01/09.
And this driver makes flashes on my screen.
I use USB-C interface.
JChas2
I had the same issue. Use the latest 8xxx.xxxx drivers from the Graphics driver page
Nantoka
Thank you Al.
I have DELL XPS 13(9380) with i7-8565U.
https://ark.intel.com/content/www/us/en/ark/products/149091/intel-core-i7-8565u-processor-8m-cache-up-to-4-60-ghz.html
i7-8565U processor has the same resolution.
But it can output 5120x1440 resolution.
Following dell support page tells me Intel UHD Graphics chips can output 5120x1440 via USB-C interface.
https://www.dell.com/support/article/en-us/sln314416/dell-u4919dw-system-requirements-and-supported-configuration?lang=en
AlHill
I see you have updated your initial post.
Doc
Nantoka
I'm sorry I didn't explain it enough.
What I wanted to say was i7-8565U processor is outputting 5120x1440 resolution, so i7-10710u processor should be able to.
Because both processors have the same graphics specification and the above dell support page tells me Intel UHD Graphics chips can output that resolution.
n_scott_pearson
Super User Retired Employee
Is the adapter you are plugging into the​ USB-C interface Thunderbolt 3-compliant?
JChas2
Nantoka
Thank you Jchas2.
The latest driver(26.20.100.8141) brought me the maximum resolution.
