Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13497 Discussions
BXNUC10i7FNHAA1 recent problem
Benny55
I have a BXNUC10i7FNHAA1 that I have been using since February
Recently I upgraded to windows 11
Over the last few weeks the unit will just quit and reboot and if I am not mistaken it happens when I am writing an email My company uses google as the provider but I am not sure if that is the case each time.
LeonWaksman
Hi @Benny55
It doesn't seems to me that GMAIL is causing this problem, since this not an application rather this an Internet Site, many people are using, including me.  It can be something wrong in Windows 11 installation, causing this crash.
I suggest that you take the following steps to fix this problem:
1. Download and install the Chipset Software and then reboot your NUC.
2. Download and install the Intel Driver & Support Assistant and run it to update all drivers on your NUC.
3. If your BIOS is not updated yet to Version 0053, download FNCML.0053.EBU.exeDouble click on this exe and follow the instruction on screen to update BIOS.
4. If still you will have the crashes, Repair your Windows 11 with an in Place Upgrade.  Your Windows will be replaced, without affecting your data and programs.
Leon
Benny55
Thanks Leon
I have followed your instructions and will wait to see if it still does it
To be honest I knew it should not be Google causing it but it was where I was at when it has occurred to my recollection.
It happened once when I was on an important video conference sending a colleague a note
That what sticks in my head
Again Thanks
LeonWaksman
Which part of my recommendation did you applied? All of them?
Leon
Benny55
Hi Leon
All but #4 as you said to do that if crashes continue
