I have Intel NUC8i7BEH with Ubuntu Linux 19.10
Kernel version: 5.3.0-24-generic
BIOS version: BECFL357.86A.0077.2019.1127.1452
By default "Balanced" cooling profile was selected in BIOS. In this profile fan speed is 2300rpm with system IDLE and basic OS usage, which is loud and uncomfortable for me.
After read other questions in the forum
* https://forums.intel.com/s/question/0D50P00004EgUqNSAV/nuc8i7beh-high-fan-noise
* https://forums.intel.com/s/question/0D50P0000490SGwSAM/nuc6i7kyk-skull-canyon-nuc-runs-hot
I use the "Custom" profile with following settings:
Fan Control Mode: Custom
Primary Temperature Sensor: Processor
Fan off capability: off
Minimum Temperature: 75
Minimum Duty Cycle: 20
Duty Cycle Increment: 4
Second Temperature Sensor: Memory
Minimum Temperature: 65
Now fan speed is 1300rpm and process temperature is around 40-42C during basic operation system usage, e.g. browsing in the internet. So, fan sound is comfortable.
But, if perform some heavy tasks fan SUDDENLY becomes VERY loud (> 4000rpm). The problem here is fan doesn't increase speed when temperature comes closer to the Minimum Temperature. I expect more smooth fan curve, e.g. like this https://github.com/pop-os/system76-power/blob/7a43106205b63d159b2c17ef848f3f9abbcaed19/src/fan.rs#L2...:
Temperature | Duty
< 40 | 0
40 | 10
45 | 30
55 | 35
65 | 40
75 | 45
80 | 50
90 | 100
Moreover, fan speed sensor is not detected by Linux Kernel, and therefore it's not possible to control fan speed from OS level.
So, my questions: Why fan speed curve so sharp? Can I make it smoother? (i.e., increase fan speed more evenly).
The fan speed increase with each degree rise is controlled by the value of Duty Cycle Increment. In your custom setting, after reaching the Minimum Temperature of 75 DEG, the fan will increase speed by 4%/1DEG C. So, since your Minimum Duty Cycle is set to 20 %, when the CPU temperature reaches 95 DEG C, the fan will reach 100 % speed (Delta temperature 20 DEG C x 4% = 80%; 20% + 80% = 100%).
I would try to change the Minimum Temperature of 80 DEG and the Minimum Duty Cycle is set to 30 %. With those settings in normal use you will have still quiet NUC, less sensitive for triggering the FAN, while still getting 100 % fan speed at 97.5 DEG C.
Leon
Thanks! I will try.
Hello guys, Leon
The problem with this fan speed regulation, it has a high delay. When I run some cpu tests, temperature raise up to 80 and fan speed controller still do not notice (some smoothing/filtering of measured temperature as input to our rpm formula?) Then suddenly, it wake up (sometime even after 10s) and fan goes straigh 100% - where it is extremely loud.
Guys, are you sure also Windows does not play some role here? In power settings, you can choose active or passive aproach.
I have 25% as minimum, min temp 55, step 2%
Hello @DKoma3 ,
Leon
