Community
cancel
Showing results for
Search instead for
Did you mean:
DLang6
Bayhub Tech SDCARD Reader Driver issue
Intel Drver & Support Assistant says there is a new Bayhub Tech Driver https://downloadcenter.intel.com/downloads/eula/27878/Bayhub-Tech-Card-Reader-Driver-for-Intel-NUC-K... Bayhub Tech* Card Reader Driver for Intel® NUC Kit NUC8i7HNK, NUC8i7HVK . Will not update and windows says the version 1 driver is still the best. Am I the only one with this issue?
Community Manager
Hello Snowgod,
Thank you for joining the Intel Community Support.
Because the Intel® DSA may be causing this issue, I would like to do further research about it. A workaround would be to install the driver manually. To check if this is an option, please run the Intel® System Support Utility.
Follow these steps:
1.Download the Intel® System Support Utility.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91...
2.Open the application, make sure that Third Party logs is checked, and click Scan to see system and device information. The Intel® System Support Utility defaults to the Summary View on the output screen following the scan. Click the menu where it says summary to change to Detailed View.
3.To save your scan, click Next and click Save. You can save the file to any accessible location on your computer.
4. Attach the report to this thread.
Wanner G.
MLevi
Valued Contributor I
One of the greatest benefits on this blog is the ability to have a dialogue with technical-minded people at Intel.
Second to that is the contributions of everyone. Great Stuff.
However, with the publication of this tool, I have to say that I'm really enjoying discovering them.
Thanks for the link Wanner G.
LHill_Intel
Hi Snowgod,
I checked that metadata in iDSA and identified a versioning issue. That's been fixed now, so within the next few hours, iDSA should present the correct information. The problem is when the actual driver version that gets installed is different from the driver 'package' version.
Lois H.
Intel Customer Support
DLang6
I thank you for your quick response. issue has now been resolved.
