Intel® NUCs
12300 Discussions
Beast Canyon - F10 Boot going in bios instead of Boot device selector
Sand2010
HI All,
Looking for some assistance in loading windows onto my new nuc, as I just can not get it to a the boot selector screen
I have read the forums and can not find a solution that will allow me to get to the F10 Boot screen.
Every time I hit F10 it takes me straight to the bios screen, ie like I hit f2.
I have tried different settings, reset back to factory default all with no luck.
Any assistance would be greatly appreciated
Thanks Shaun
LeonWaksman
While in BIOS, set your installation USB as a first boot device. This will not solve your problem, but you will be able to install Windows.
You may also try  to update BIOS, using the Recovery Method with the Yellow Security Jumper removed.
Leon
n_scott_pearson
Super User Retired Employee
What you are seeing shouldn't happen if the media is UEFI-bootable. If this is media to install Windows 10, then use the Microsoft tool to recreate this media (available here: https://support.microsoft.com/en-us/windows/create-installation-media-for-windows-99a58364-8c02-206f...).
Hope this helps,
