Intel® NUCs
Support for Intel® NUC products
Do you have improvements you would like us to make on this community site? If so, we would love to hear your feedback! Click here for an 8 question survey. Thanks!
11314 Discussions
Best PC controls when sitting in a sofa?
RTayl10
What's the best PC controls when sitting in a sofa?
The computer is an Intel NUC connected to a 42" TV screen.
And it works fine as movie-player and internet browser.
But the current PC controls on a low table connected to it are no good for gaming or long time browsing because of the sofa. One has to sit akward to use them...
RTayl10
Perhaps this is the best controls setup for using Intel NUC in the livingroom?
It's called couchmaster! Does Intel have a cheaper solution?
Miguel_C_Old
Intel has a list of tested Peripherals with Intel® NUC Boards and Kits
http://www.intel.com/support/motherboards/desktop/sb/CS-034983.htm Intel® NUC Boards and Kits — Tested Peripherals
Mike C
GKlug1
Hi PvP,
the NUC has a infared sensor but i prefer to use a thin and low weight bluetooth keyboard with Touchpad.
A good one has enough power for several months of using and a modern akku / load station
RTayl10
What kind of sofa equipment is the infrared sensor useful for? Internet browsing or television?
This NUC is connected to internet via cable. But there is an internet router right next to it and it seems like quite a lot of trouble to buy a bluetooth card and opening up the NUC completely to place it at the bottom if only to discover that it interferes with the WiFi signal from the router...
But are there a useful bluetooth mouse when sitting in a sofa, since it needs an underlayer to roll on?
RTayl10
Miguel_C_Old
Hi Pvp,
Thank you for your feedback.
Mike C
