Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Best way to connect hi res display?
what's the best way to connect a display (QHD or 4K) to my NUC7i5BNK? HDMI/HDMI, HDMI/Displayport (with adapter), Thunderbolt/HDMI or Thunderbolt/Displayport?
Thanks for sharing your experience,
Stefano
Highlighted
Community Manager
Hi Stefano.Fereri,
Thank you for choosing Intel products, let me help you on this matter.
For 4K video support, you need:
High-speed HDMI cable. Standard-speed HDMI cables will not support 4K.
DisplayPort to DisplayPort video cable.
The usage of video cables might limit resolution size.
Please check the following information about 4k resolution
https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/NUC7i5BN_NUC7i7BN_TechProdSp... https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/NUC7i5BN_NUC7i7BN_TechProdSp...
Page 23-24
Hope it helps,
Allan J.
Highlighted
Hi Allan,
thanks for input. My problem is that I plan to use an Eizo EV3237. This display is not capable of 4K/60Hz via HDMI, only via DP. So I cannot use HDMI to HDMI cable nor DisplayPort to DisplayPort cable (the NUC has not DP). Having 4K with 60Hz will not work in this scenario, right? Or could I use DP to HDMI adapter?
Stefano
Highlighted
Super User Retired Employee
Remember that the native output of the processor is DP. It takes a DP-to-HDMI IC to facilitate the HDMI output.
Now, the output in the TBT stream *is* DP. Thus, to support your 4K DP monitor, your best bet is a TBT-to-DP adaptor.
Hope this helps,
Highlighted
That's the information I need! Thanks a lot,
Stefano
