Intel® NUCs
Bios Update
AdrianChis
Hello. I can't update the Bios on my Intel Nuc M15 device.
Please help out.
n_scott_pearson
Super User Retired Employee
I would suggest that you download the latest Recovery BIOS image and attempt a BIOS Recovery. This process is documented here: BIOS Update and Recovery Instructions for Intel® NUC Laptop Kits with the Aptio® V UEFI Firmware BIO....
Hope this helps,
Alberto_R_Intel
AdrianChis, Thank you for posting in the Intel® Communities Support.
In the following link, you will see BIOS version 0073, which is the latest one for the Intel® NUC M15 Laptop Kit - LAPBC510, in order to download it. We always recommend not to jump all the way to the latest version, so first, install BIOS version 0071, then 0072, and after that 0074, you will find all those versions on this same link:
https://www.intel.com/content/www/us/en/download/19683/bios-update-for-the-intel-nuc-m15-laptop-kit-...
There are different ways to do the BIOS update, in the link below you will find the instructions for each method on how to do the update, we advise you to use the F7 method:
https://downloadmirror.intel.com/730597/NUC-Laptop-Kit-Aptio5-BIOS-Update-Readme.pdf
Here you have further details about those same procedures:
https://www.intel.com/content/www/us/en/support/articles/000056678/intel-nuc/intel-nuc-laptop-kits.h...
Albert R.
AdrianChis
Hello Albert,
I want to thank you for the feedback but unfortunately the result is the same.
I downloaded the BC0071.cap (the version you recommended). After shutting down the device and inserting the flash drive, I pressed f7 at power-up and the device entered Bios, where I chose the update and I was prompted with: "Are you sure you wish to update the BIOS with BC0071.CAP?". I chose "yes" and the device restarted but with the same "Check FW Capsule Data. Block Capsule Update by OEM FW Capsule data."
I had no luck (:
Please help me out!
A.
AdrianChis
If it helps:
BIOS
Version
0051
Date
12/7/2020
Motherboard
Manufacturer
Intel Corporation
Model
LAPBC510
Version
M13916-502
Operating System
Edition
Microsoft Windows 10 Pro (64-bit)
Version (Build)
21H2 (10.0.19044)
  • Device Details
  • ManufacturerGenuineIntel
  • DescriptionIntel64 Family 6 Model 140 Stepping 1
  • Architecturex64
  • # of Cores4
  • # of Threads8
  • Processor Base Frequency2419 MHz
  • Current Voltage7.
  • Level 2 Cache5120 Kb
  • Level 3 Cache8192 Kb
  • Processor Id0x806C1
  • AvailabilityRunning at full power
  • Driver Details
  • ProviderIntel Corporation
  • Version27.20.100.8729
  • Date9/11/2020
  • Device Details
  • Adapter CompatibilityIntel Corporation
  • Video ProcessorIntel® Iris® Xe Graphics Family
  • Resolution1920 x 1080
  • Bits Per Pixel32
  • Number of Colors4294967296
  • Refresh Rate - Current60 Hz
  • Refresh Rate - Maximum60 Hz
  • Refresh Rate - Minimum40 Hz
  • Adapter DAC TypeInternal
  • Adapter RAM1.00 GB
  • StatusThis device is working properly.
  • LocationPCI bus 0, device 2, function 0
  • Device IdPCI\VEN_8086&DEV_9A49&SUBSYS_22128086&REV_01\3&11583659&0&10
  • Driver Details
  • ProviderMicrosoft
  • Version10.0.19041.789
  • Date6/21/2006
  • Firmware Details
  • VersionSTNSC014
  • Device Details
  • Capacity465.76 GB
  • Serial Number0024_CF01_4C00_B513.
  • Partitions3
  • Device IdSCSI\DISK&VEN_NVME&PROD_SEAGATE_FIRECUDA\5&54F4B11&0&000000
  • Device Path\\.\PHYSICALDRIVE0
  • C:
  • File SystemNTFS
  • CompressedFalse
  • Capacity465.15 GB
  • Free Space359.47 GB
n_scott_pearson
Hope this helps,
AdrianChis
Thank you. I had the answer under my nose but I did not imagine it needed a recovery since it had the symptoms out of the box.
Thanks again, for your time and help.
Cheers and have a great day!!!!!
