I have a nuc DN2820FYK running GNU/Linux, it mostly works fine except for the graphics card, I never was able to control the brigthness, it is running always to maximun brightness and it is burning my eyes so this time I did some debugging following this page: https://wiki.ubuntu.com/Kernel/Debugging/Backlight# Into_the_abyss:_looking_at_the_ACPI_BIOS Kernel/Debugging/Backlight - Ubuntu Wiki and indeed it seems the bios (I'm running the lastest version - 059) is not exposing the ACPI methods for backlight control (_BCL, _BCM, _BCQ). Since writing ACPI methods is out of my reach I would like to known if some community member can help me in some way.
this is that I have tried:
first I boot the operating system with kernel parameters as recommend by https://wiki.archlinux.org/index.php/backlight# Kernel_command-line_options https://wiki.archlinux.org/index.php/backlight# Kernel_command-line_options , but no matter what parameters I use it never works, using any combination of acpi_backlight and acpi_osi results in not backlight controls:
nuc ~ # ls -l /sys/class/backlight/
total 0
nuc ~ # acpidump -o acpidump.txt
nuc ~ # acpixtract acpidump.txt
Intel ACPI Component Architecture
ACPI Binary Table Extraction Utility version 20160729-64
Copyright (c) 2000 - 2016 Intel Corporation
Acpi table [DSDT] - 46249 bytes written to dsdt.dat
Acpi table [SSDT] - 1891 bytes written to ssdt1.dat
Acpi table [SSDT] - 656 bytes written to ssdt2.dat
Acpi table [SSDT] - 378 bytes written to ssdt3.dat
Acpi table [SSDT] - 351 bytes written to ssdt4.dat
Acpi table [SSDT] - 1088 bytes written to ssdt5.dat
Acpi table [SSDT] - 141 bytes written to ssdt6.dat
Acpi table [SSDT] - 1075 bytes written to ssdt7.dat
8 binary ACPI tables extracted
nuc ~ # iasl -d *dat 2>&1 | grep Output
ASL Output: dsdt.dsl - 426096 bytes
ASL Output: ssdt1.dsl - 9929 bytes
ASL Output: ssdt2.dsl - 7673 bytes
ASL Output: ssdt3.dsl - 4371 bytes
ASL Output: ssdt4.dsl - 2919 bytes
ASL Output: ssdt5.dsl - 9649 bytes
ASL Output: ssdt6.dsl - 1323 bytes
ASL Output: ssdt7.dsl - 16934 bytes
nuc ~ # grep _BCL *dsl
nuc ~ # grep -i -e linux -e windows *dsl
dsdt.dsl: If (_OSI ("Windows 2001"))
dsdt.dsl: If (_OSI ("Windows 2001 SP1"))
dsdt.dsl: If (_OSI ("Windows 2001 SP2"))
dsdt.dsl: If (_OSI ("Windows 2006"))
dsdt.dsl: If (_OSI ("Windows 2009"))
dsdt.dsl: If (_OSI ("Windows 2012"))
dsdt.dsl: If (_OSI ("Windows 2013"))
dsdt.dsl: Name (_CID, EisaId ("PNP0D80") /* Windows-compatible System Power Management Controller */) // _CID: Compatible ID
nuc ~ #
there are strings for Windows but not for Linux.
any comment will be welcome, thank you.
intel-2820: Thank you very much for joining the Intel® NUC communities. We are sorry to hear the NUC is not working properly.
Just to let you know, the tests performed by Intel on the NUC were done using Windows as operating system. However we know that a lot of NUC owners are using it successfully on many different Linux distros. We will do further research on this matter, in the mean time, please get in contact with the forums support for Linux, in there you will receive peer to peer assistance and the might have additional suggestions to fix this problem, please let us know the results:
http://www.linuxforums.org/forum/ http://www.linuxforums.org/forum/
Any further questions, please let me know.
Alberto R
