I have inherited a NUC DN2820FYK recently.
It's having trouble loading windows 10.
Tells me it ran into an "unexpected error "
Tried updating bios using a file FYBT10H. 86A.0072.BI but that failed.
I'm guessing that is the right bios file?
I'd appreciate any help from those with more knowledge than me. So if you have any suggestions please let me know
Relevant pictures attached
Cheers
Peter
PeterWaldron, Thank you for posting in the Intel® Communities Support.
Just to let you know, the Intel® NUC Kit DN2820FYKH is under status of: End Of Interactive Support / Discontinued, as you can confirm in the following link:
https://ark.intel.com/content/www/us/en/ark/products/78953/intel-nuc-kit-dn2820fykh.html
As an option you may want to try our Discontinued Products Community to get recommendations from fellow community members.:
https://communities.intel.com/community/tech/discontinued-products
Or you may also find the Discontinued Products Website helpful to address your request:
https://www.intel.com/content/www/us/en/support/discontinued-products.html
Albert R.
A Contingent Worker at Intel
That's the correct BIOS identifier and even the correct version. Just in case, I have attached a ZIP file containing the .BIO file and the release notes.
Place this .BIO file onto a USB flash drive, insert the drive into the NUC and then press F7 during the boot process. You should set a dialog that allows you to select this USB flash drive and then this BIO file. The BIOS upgrade should progress on its own from there, providing a display of its progress onscreen.
Hope this helps,
thanks for your reply but once gain the update failed
any other ideas?
Cheers
Peter
Unfortunately the update failed again.
Not sure what to try next.
Any ideas?
Failed how? Be more verbose in your reporting.
Power on holding the power button down for ~4 seconds. When the Power Button Menu appears, use F4 to choose BIOS Recovery. It should automatically find the USB flash disk and the .BIO file.
Thanks, that worked.
Now it tells me I have to reset some jumpers (see pic)
Sorry but I need your help again.
I'm really grateful to you mate..
I found the jumper I think.
It looks like it's in the right position do you think?
Note: I suggest you go into BIOS Setup (Visual BIOS) and verify your configuration was not affected by the process.
I've now reloaded Win10 without incident.
Cheers!!
Peter
