Intel® NUCs
Assistance in Intel® NUC products
13302 Discussions
Blue flashing light
kotten
I have a NUC dc53427hye that has worked perfect under atleast 5 years now.
Today after work the NUC was powered off and it was not possible to start it again, if i press power igot some flashing and then it shut down.
I have tonight removed the RAM (i have two capsle installed) and tried to only use one of them and then i switch them and also tried both ram connectors. Nothing....
can both ram capsle broke during night?
or is is some other error?
Yesterday it was working and i always leave it poweredon
n_scott_pearson
Super User Retired Employee
Have you tried with the monitor connected to other connector?
Have you tried using a different monitor?
Have you tried using a different power supply (these are usually first to die)?
kotten
My other computer works fine with the same monitor and cable.
The power supply is almost the thing that i have not test and that is because i dont have a spare. Is there some way i can test this?
Maria_R_Intel
Hello kotten,
Thank you for posting on the Intel* Community.
Unfortunately, due to this product being discontinued, Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help. You may also find the Discontinued Products website (https://www.intel.com/content/www/us/en/support/discontinued-products.html) helpful to address your request.
You can verify this product's discontinuance status at the Intel® Product Specifications website > Product Status > "Discontinued".
Maria R.
