Hello Everyone, i've got a new Intel NUC i5 10.Gen.
My primary Display got a connection via HDMI to USB C Converter.
My second Display got a conenction via HDMI.
The Problem is that my Bluetooth in-ear buds get a connection to my Intel NUC but then my primary display shows a black screen. Then i have to reconnect the HDMI Cable which is connectec to the USB-C Converter to get a Signal on my Display. If i disconnect my bluetooth in-ear buds, i get a black screen on my primary display again.
All Driver updates are done. Does Someone know how to fix the problem?
Malik
Hello MalikGns,
1. Exact brand name of your Intel Nuc.
2. Do you have the same behavior with other Bluetooth devices?
3. Have you updated the BIOS version?
4. What is the brand name and model number of your adapter?
5. What does happen when you use only one monitor? and have you tried each monitor only with HDMI connection?
6. What does happen when you use only the monitor with the USB-C adapter?
7. Are you using the USB-C port in the back part of the Nuc?
Deivid A.
Hello Deivid,
Thanks for the fast reaction.
Hope that i can answer your questions..
1. BXNUC10i5FNK2
2. It also happened with other bluetooth devices
3. BIOS is updated
4. It's a InLine Adaptor: https://www.intos.de/produktuebersicht/eingabe-ausgabe/usb-grafikkarte/64101b/inline-usb-display-konverter-usb-typ-c-stecker-zu-hdmi-buchse-dp-alt-mode-4k2k-schwarz-0.2m?ffRefKey=V58yZSWX7
5. I tried it with both monitors. It happen the one, whic is connected to the adaptor/Converter.. It also happens when i use only one monitor
6. It happens everytime when i use a hdmi/usb c converter..
7. The usb c converter/adaptor is connected to the back of the NUC
Hope that you can get a better picture of the problem.
i will order a direct HDMI to USB C Cable.. Maybe that will fix the problem?
Best regards
Malik Günes
Hello MalikGns,
Thank you for the information provided, is very helpful
Deivid A.
Hello MalikGns,
In this case, as part troubleshooting process I would like you to try the following:
1. Disable the Bluetooth and Wi-Fi from the BIOS. BIOS>Devices>onboard devices> unchecked "Bluetooth" and "WLAN"
2. Were you able to test with the straight HDMI to USB-C? What was the result?\
Please let me know the outcome of this test.
Deivid A.
Hello MalikGns,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
Hey, sorry i had a business trip.
I checked a straight HDMI to USB C cable, but the problem couldn't be solved.. Still the same.
I did not disabled bluetooth and wifi from the BIOS so far. The question is how to use bluetooth when i disable it from the bios? i need it.
regards
Malik Günes
Hello MalikGns,
In this case, by disabling the Bluetooth and Wi-Fi, I would like to check/confirm if the in-ear buds cause any kind of electronic interference either coming from the HDMI/USBC adapter or the wifi/BT adapter on the NUC.
Do not hesitate to let me know the outcome of this test.
Deivid A.
Hello Deivid,
before i disabled bluetooth and wifi from the bios i noticed something..
I have a speakerphone from Byerdynamic whic i connected via usb to my Intel NUC.. and my Monitor showed a black screen again.. so the same problem with my bluetooth in ear headset.
However i disabled bluetooth and wifi from bios and there was no function of bluetooth and wifi on my desktop anymore. I tried to connect my bluetooth in ear headset.. Of course he could not find my intel nuc and my monitor did not show any problems and all signals were there.
Do you have another option to try something out?
regards Malik
Hello MalikGns,
Deivid A.
Hello MalikGns,
Thanks for your patience, and based on the internal research look like the NUC may be damaged/defective. I recommend you to get in contact with us directly to check the warranty options for you.
You can use the link that works better for you:
US Canada: https://www.intel.com/content/www/us/en/support/contact-support.html#@11
Europe, Middle East, and Africa: https://www.intel.com/content/www/us/en/support/contact-support/emea-contact.html
Asia-Pacific: https://www.intel.com/content/www/us/en/support/contact-support/apac-contact.html
Latin America: https://www.intel.la/content/www/xl/es/support/contact-support/lar-contact.html
Deivid A.
